Fridge section is not cooling but freezer is cold
SOURCE: Warm Fridge Section
sounds like the evaporator fan in the freezer is not moving the air. also there is an air damper door at the top center of the fridge that controls air flow from the freezer to the fridge. check those two components and you will find your problem.
SOURCE: Warm Fridge Section, Cool freezer section
Problem seems to be solved. I unplugged it for a short time and plugged it back in. I'm guessing it needed to be re-set.
SOURCE: Refrigator not cooling properly, freezer works fine
I'll assume you don't have much food/items in the freezer section. Because you have the fridge set on the max cooling setting and the freezer set higher than the mid setting, it could be that you have frozen the cold air passage from the freezer to the fridge.
If you can, 1) remove all contents that would spoil; 2) turn off the fridge 3) open both doors and allow the fridge to manually thaw out completely (this will speed up the opening of the cold air exchange passage between the freezer and fridge, which is likely blocked and frozen solid. Have plenty of towels handy to soak up the water from the defrosting process,
After a FULL day of being left off and doors open to thaw out, check for any further thawing and dripping water inside, if present wait another 8 hours (you really want to get it thawed out the first time!) When that's done, reset BOTH temperature controls to the factory mid-point setting (5?) as marked on your control knobs.
The key to having a refridgerator run properly is to allow for it to run at the factory settings for at least 24 hours BEFORE you adjust the controls higher and/or lower for each section. Adjust it up or down in ONLY 1 setting increments so as to not cause ice build-up and freezing of the internal air exchange passages.
Also, as you've relegated this fridge as a garage "beer & backup" unit, make sure to keep the freezer as full as possible to make it run as efficiently as possible. You can freeze jugs of water and pack it with cheap thrift store bread to help it run correctly. An empty freezer has to work harder to keep just air at freezing temps. As such, it will pass much colder air into the fridge, and cause these types of freeze ups. By the way, turning up the temp controls only makes it worse and just results in a total "freeze up" inside the cabinet panels that you can't easily see or get at to rectify, hence the reason to shut it off and let it fully defrost.
When you're done, you should have your fridge back in action working like it should, but remember, don't rush temperature adjustments, even thou we all want those frosty beverages, it'll take a couple of days to achieve the desired "chill" you're likely used to getting when it was your primary fridge.
Hope this helps and Best Regards! Semper Fi!
SOURCE: KitchenAid Superba fridge section not cooling, freezer is cold.
You have done a good job of attempting to diagnose by process of elimination, but this is a more complex system. I have provided some links below to assist you in diagnosing your problem. Links courtesy of www.repairclinic.com.
1. Ascertain that the evaporator fan is operational. This may be controlled by the Door Switch, (No.4) and could cause the fan to be inoperable.
2. Ascertain that the Fresh Food compartment light goes off when door is closed.
3. The air diffuser may be faulty by not controlling the air flow from the freezer properly
Tip: Always maintain dual temperature control settings at equal or +/- 1 setting position.
How refrigerators work:
http://www.repairclinic.com/0088_4_3.asp
You will need to verify operation of the following components listed below:
1. Evaporator fan motor
2. Air diffuser assembly
3. Light switch for refrigerator/freezer light
4. Door switch
Click on the links to identify the parts listed
1.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di921541&PartID=921541
2.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di827263&PartID=827263
3.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di438889&PartID=438889
4.http://www.repairclinic.com/SSPartDetail.aspx?s=t-KSRS22F69913-%3d%3di586519&PartID=586519
Parts breakdown diagram:
http://www.repairclinic.com/Refrigerator-Side-By-Side-Appliance-Diagram
The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located.------------ But as you mentioned that freezer not cooling this indicates problem with compressor.When compressor cools the freezer section then fridge section gets cold.If freezer section is not getting properly cold then fridge section will not cool properly/.So the problem relates to compressor.---------- In the compressor there is a refrigerant called FREON.With the help of this Freon the compressor cools the freezer section.Freon is a gaseous type cooling agent.The compressor will stop cooling when coolant gets leaked from its chamber.--------- Again recharging the Freon is possible, but the cost for that recharging is approx the cost of new compressor.So its always advisable to get compressor replaced.Because new compressor has warranty for few years.------------------ You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
When the freezer section gets cold and reaches its required cooling temperature, after that the frost on freezer section starts defrosting and the cooling fan in the freezer section blows this cool air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the freezer gets cool but fridge section does not cool.
Its defrost problem. Try manual defrost by unplugging the refrigerator from main power outlet for 24 hours then reconnect it and check, if the same problem is noticed again,. If yes then its defrost board problem. The defrost board located in the back of fridge section. You can get required parts from www.repairclinic.com or from online sears part site. ------------- Thank you.
