SOURCE: the proform 980 turns on but just goes to incline
It is trying to its starting point I would suggest is to unplug the unit open the motor shroud unit. The shroud it has a mini manual this should have a calibration instructions that can be done and also upper electronics self test to see if the processor is functioning properly. It should give a better idea which to head. You can call Icon Fitness@ 1-800999-3756
1) tight all connector wires and clean
2) tight the ribbon cables from keypads.
3) Run the software calibration for diagnose, and troubleshooting, and fix it.
4) lube the shaft and gear in the elevation motor,
5) adjust the potentiometer for better running see the diagram.
God bless you
