PANDIGITAL Digital Book 843967071153 Tablet PC Logo
A
Anonymous Posted on Jun 11, 2014
Where can i get a charger for my tablet - PANDIGITAL Digital Book 843967071153 Tablet PC
My tablet won't charge
First try to charge it with a different charger, and test the factory charger on another device (you tablet may have the common micro USB connector). This will test if the charger or cable are bad. But if the tablet will not charge with a different charger and cable, and it is still covered under the factory warranty, return it for a refund or a replacement.
I have repaired many tablets with a bad charger port, and it seems to be either a poorly designed connector, or an open wire inside due to pushing in too ******* the cable into the port.
if you cannot replace the tablet, maybe you can find help from someone who can open the tablet and fix the charger port.
1helpful
Can I charge a tablet with a cell phone charger?
You should check the Voltage and Amperage rate of your tablet's charger, should be same of cell phone.
If you've lost your tablet charger and you are not sure, don't do it. You might fry some circuits of your tablet by Voltage overcharge
Ask someone with a similar tablet for this info, It is on any charger
1helpful
2answers
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
2helpful
2answers
I just purchased the android tablet and the charger is not working, I am using my phone charger to charge it, is there a way you can send me a new charger and also I need a stylist for it. Thank you.
Sorry Patricia,
We don't sell tablets, we only try to answer questions. You should try to contact the firm you bought the tablet and ask them. It could be the tablet does not come with a charger. For that just look on the net, what a complete package for your tablet is.
I would not tell the shop I tried others chargers, because if the tablet is defect they will blame you for not using the right charger.
Not knowing what tablet it is I even can't give an advice on how you could charge it, because lots of tablets can be charged with an USB cord, connected to a computer.
Trouble charging a Digland 10.1" tablet
Did the charger that you are using come with the Tablets? Many 5 volt chargers can only output a 0.5 to 1amp current, while a Tablet typically needs 2 to 2.5 amps charging current. So, if you're using a charger from some other device, then it's almost certain that it cannot provide a sufficient current for the Tablet, and the charger overloads, shuts down cools off, turns on again, overloads again, shuts down etc repeatedly - giving the exact symptom you are reporting.
Even if the charger did come with the Tablet, some of the Chinese ones are of very poor quality and cannot provide reliable service. A replacement charger rated to suit your Tablet (there should be something in the specifications that came with the Tablet listing the requirements for the charger) should solve your problem {:o)
Digiland tablet won't charge. Is there a way to
Depends upon exactly what's happening.
  • When you plug in your charger, does it try to charge the Tablet? ie Does the Charging icon come on the screen briefly when the charger is plugged in with the Tablet turned off, or does the little charging 'lightning' symbol come onto the battery icon on the home screen when the Tablet is running?
  • I assume the battery has gone flat, but will the Tablet turn on when the charger is connected?
If the charging icon comes on, and/or the tablet will run on the charger, then both the charger and the charge port connection on the Tablet are OK, and the most probable cause of failure is the internal battery which will need to be replaced.
However, If neither the icon comes on nor the Tablet runs on the charger, then either the charger has died, or the plug/socket on the Tablet where it connects is faulty. The most likely cause is that the charger has died and will neeed to be replaced
There is a slight chance that the internal charging circuits in the Tablet may have developed a fault, but that is highly unlikely {:o)
2answers
Where can I buy a charger for my trio stealth g2 tablet?
I was able to use my cell phone charger when my Trio Stealth Tablet charger stopped working. I would suggest first trying to use a basic cell phone charger before going out and spending lots of money on a charger "specifically" for a tablet.
1helpful
Visual Land Prestige won't charge
take the tablet to a store that sells charger , ask if you can test it before you buy it
Will not turn on
If tablet keeps burning out charges it is due to the fact that an internal short in the tablet is making the charging unit exceed its parameters and allowing it to burn itself out. The issue is with the tablet, not the chargers.
Maylong mobility tablet's charger
Hi E/BAY HAS SOME MAYLONG CHARGERS. type in e/bay search .( Maylong tablet charger ).cheers
Top PANDIGITAL Tablets & eReaders Experts
Paul Bade
ADMIN Andrew
ADMIN Andrew
Are you a PANDIGITAL Tablet and eReader Expert? Answer questions, earn points and help others
