Question about Brother CS-6000
I have a Brother cs-6000. The bottom of the bobbin rewinder hits agains the the bar when it tries to rewind. It's the little part that you put the end of the tread through after you put the bobbin on. Then I move it to the right and it bumps the bar asnd wont wind.
4 Suggested Answers
SOURCE: I need to rewind a new bobbin
My SE-270D bobbin winder is located on the top of the machine to the far right. From the picture of your machine it looks to be in the same place. The larger spindle is for the spool of thread and the shorter spindle is for the bobbin.
You need to wnd the thread around the bobbin a few times just to make sure it is started properly, and then move the bobbin either forward or backward to engage. (It's different on some machines.) You may also have to move the outer edge of the machine wheel (the large wheel on the outside right) to keep the needle from moving up and down while the bobbin is filling. When the bobbin is full the machine should shut off by itself.
Then you will have to re-tighten the machine wheel to engage the needle.
Hope this helps.
Posted on Apr 05, 2009
Anonymous
  • 8 Answers
SOURCE: brother CS 8060 bobbin wont wind...but motor runs
no idea... did you lock thread onto bobbin so it holds to wind?
Posted on Jul 18, 2009
paj42
  • 1116 Answers
SOURCE: bobbin will not rewind
SE270D. Lift the bobbin and reposition, making sure it is down against the pin.
If this is not the problem, a Sidewinder Bobbin Winder (auxiliary bobbin winder sold with most sewing notions) is a lot cheaper than taking the machine in for service.
Posted on Mar 14, 2010
ju222dy
Judy Tew
  • 8 Answers
SOURCE: Cannot wind the bobbin
Mine stopped working too. Gave up and wound bobbins by hand for a while until I broke down and took the machine apart -- an ordeal to figure out. I found that a pliable ring on the winder was completely disintegrated (gummy plastic-like stuff). An online search found this -- a bobbin "tire" which I THINK is the part I need: http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx. Hope this helps. --Also cleaned all the lint out when I had the machine opened up. They don't make it EASY!
Posted on Aug 09, 2012
How to trouble shoot without a manual?
you can download a free manual at //www.generalmanual.com/Home-Sewing-Embroidery-Machines/Brother-CS-6000i-Sewing-Machine.htm
F4 might mean that the bobbin on the top is in the position for rewind, slide bobbin to the right for the error code to go away. Hope this helps, Sandy
May 03, 2014 | Brother CS-6000i CS6000i 60-Stitch...
Brother cs-6000 will not sew, the top thread go through and tangles on back, and the bobbin thread is a straight line and can be easily pulled out, please help, trying to make kids school clothes
Hi:
Ok... so try to remember that loopy stuff on top means the bobbin tension is too loose (or the top tension is too tight...)
Loopy stuff on bottom, means the top tension is too loose. (or it's not threaded right)
Now. Get some scrap of the same material. Loosen that bobbin back to where it was. RETHREAD the top, with the foot in the UP position.
Place your scrap under the foot, and sew. still have problem? clip your threads and try again only this time hold the top and bottom threads off to the side as you begin to sew. How did that do?
Adjust the top tension to the point where you start seeing the bobbin thread come up in loops to the top... then back off until the disappear.
Now... be sure you have the correct thread and needle for your fabric. A lot of problem are caused by not having the proper needle and thread.
Jul 09, 2012 | Brother CS-6000
Bobbin will not rewind
Mar 14, 2010 | Brother Sewing Machines
Brother CS-80 Sewing Machine Bobbin Rewind
For $30 you can buy a standalone bobbin winder (Sidewinder) at JoAnn's Fabrics or Amazon. It's a great little accessory (battery or electrical) because it saves wear and tear on your machine but also allows you to wind multiple bobbins without having to unthread the machine.
Nov 09, 2017 | Brother CS-80
I took my maching apart to clean the lint out and when I put it back to together the needle is hitting the feed dogs. what could be causing this!
most likely the bobbin case is not aligned correctly .Insert the bobbin case so that the projection on the boobin case aligns with the spring.
Feb 23, 2009 | Brother CS-6000
My needle hits metal
You have to be putting the bobin in the wrong way or it is not all the way in. I hopr this helps.
Feb 04, 2009 | Brother CS-6000
Brother CS-6000 Sewing Machine - Jam
I have the same problem and found that the bobbin case is scratched. These are quite expensive so I hope yours is something more simple. Keeping the bobbin area clean is also a necessity.
Jul 28, 2008 | Brother CS-6000
Rewinding bobbin
many old machines have problems with worn out parts check the link attached , perhaps it is a good alterative https://www.walmart.com/search/?query=bobbin%20winder&typeahead=bobbin
Mar 30, 2017 | Sewing Machines
Can't get Bobbin to wind properly
Verify that your thread path is correct when winding the bobbin. It has a distinctive path including a tensioner that helps your thread wind smoothly. Do not use a bobbin that is not wound smoothly because (as you already know) it could possibly break needles and damage the machine.
Brother CS 80 Sewing Machine Bobbin Rewind
Nov 09, 2017 | Kenmore 15208 Mechanical Sewing Machine
Brother CS-6000 Logo
76 people viewed this question
Top Brother Sewing Machines Experts
Irene Tulloch
Douglas Plant
Douglas Plant
PHYLLIS SMITH
Level 1 Expert
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
