SOURCE: My Miele electric cooktop is completely out,
If the power is reaching the cooktop, can you see any power lights/leds lit on it? If there arent any their may be a fuse inside the cooktop that has blown, perhaps because of a fault. Unplug it turn the unit over and remove any covers on the electronics, use a bright light and have a good look for blackened (charcoal) marks on wiring or circuit boards. If there are any it, it has suffered a failure and the item that has failed may be the blackened part or any other, so the only way to be sure of fixing it is to replace all the electronics, hence it will be cheaper to buy a new cooker top.
Your
problem could be or probably is with the regulator...too much gas
pressure...
Propane,
LP, or Natural Gas Regulator Problems
heatman101
