Samsung Np305v5a-a0cus Amd 4x A6-3410mx 1.6ghz 4gb 500gb Dvd+/-rw 15.6 Win 7 [black]
SOURCE: samsung cd/dvd drive
The first thing I try in this error is to remove the upper lower filters
http://support.microsoft.com/kb/314060
If that doesn't resolve, then time to check cable connections and BIOS settings to ensure the drive is seen by the motherboard.
SOURCE: PC CD DVD RW is not recognised as a burner. Win Media asks for a burner
use some other burner applicaton like nero burning rom.
SOURCE: Dics Drive Upgrade for Toshiba Satillate.
As far as i know thats impossible. Your optical diskdrive is made just for those speeds that you have on it. You cant change the manufacture settings and speed it upp, or make it to an dual layer disk.
Buy a new one whit the needs that u want and replace the old one. Its easy done and its not that expensive.
Good luck to you
Nic
SOURCE: I want to install Windows 7 on my laptop, it
If you are updating from Winos XP orsome higher version to Windows 7, an automatic update is run which backup allthe data, installed files and saved application settings.If you freshly install Windows 7 inyour PC, it will remove all the installed applications and saved settings.
