SOURCE: what is the oil to gas ratio for the husqvarna
Most trimmers use a 40:1 ratio on fuel mixture. Check the gas tank on your trimmer, as some manufacturers label it as an imprint in the plastic tank itself.
Hope this helps,
Chip
SOURCE: my husqvarna 125L weed eater will only run with
sometimes it's caused by too much air in the mixture---check for leaks around gasket where carb meets head--also, check the jets--make sure they are not clogged
SOURCE: in what order does a carburetor gasket kit go on a
There is only one gasket, Jenny. To figure ouut which way it goes, first put it onto the carby, then transfer it to the motor. Next put on the carby, and tighten the screws. Then hook up the electrical wiring and the fuel lines, and the job's done.
