Your laptop has a manual IP on it you will have to dis able the IP and make it automatic for it to browse the net would have been more detailed if I knew the operating system u are using
first go 2 settings. go 2 internet enter it go to connection settings. click connection 1 2 or 3. click search 4 an action point and chose any gold lock acsess point. it will show the strength( 3 bars strong conection 2 bars fair conection 1 bar weak conection 0 bars no connection.)
My name is ArmyMason, I have a suggestion for you. In Internet Explorer click on file and see if Work offline is checked. If it is unchecked it and try again. If this solution doesnt work might I suggest using our premium service or live chat.
you dont use a wirless stick on the ps3 the ps3 has wirless built into it to conect to the internet you ethier need to conect it to a router though an ethernet cable or using wirless to conect to a router
try pressing start, control panel, network and internet conections, network conections this should show your lan page then press on the lan you need to conect then it should be conect or bridge conections
check there is no firewall blocking conection to internet and that you can conect to internet also check what the url is on conections in avg menu this tells avg were to conect for updates
conect in your lan cross conection pc to laptop .then go to network properties then go to network setup wizard & share internet conection note pc name or laptop name both two other name.
