SOURCE: How to Reset HP Laserjet M1522nf security password
Hi the easiest way is a nv ram
1. Turn the printer off
2. Hold down the down arrow and the cancel button
3. Reboot the printer while holding the buttons and hold until permanent storage is displayed. Let go of the buttons and wait for the ready message on the display.
This reset will clear all of your saved settings and contacts, if networked print
out a configuration report after resetting the printer to view the ip
address (IPV4). If the IP address has changed you will need to update
the print driver's port tab and update the port.
Good Luck
Al,
[email protected]
SOURCE: Can you help me reset
The print cartridge in these printers utilizes a non-resettable chip. If you have purchased a refilled cartridge the seller should have replaced the chip. If you just bought toner you will need to source a chip, likely Ebay will be your best bet.
SOURCE: My HP Laserjet 1536dnf MFP
10.0000 Supply Memory Error - A specific print cartridge has an e-label error.
Solution:
1.Reinstall the print cartridge.
2. Turn off and then turn on the product.
3. If the problem is not solved, replace the cartridge.
Hope this helps
