Question about Panasonic Lumix DMC-FS3 Digital Camera
Lumix DMC-LC1 turn it on just get stripes no clear photo
I haven't used the camera for a few years. Pulled it out of the case and charged the battery up. Turned it on and no picture on the screen just stripes. IS this fixable??
6ya staff
SOURCE:
Anonymous
  • 72 Answers
SOURCE: Panasonic DMC-LC1 Camera help, Black Screen
Clean everithing around the battery conections, try another battery too, check the polarity (basiks).
Try to use with the computer in webcam mode.
But dont try too hard if the common sence not workig, use the warranty!!!
Posted on Nov 11, 2007
mm46
SOURCE: Panasonic Lumix DMC-LC1 Digital Camera Problem
Contact Panasonic - there is a widespread problem with CCDs in the last 3 or 4 years - keep pressing them for free repair as is your due with faulty goods, even outside the warranty period.
See the following link:-
Widespread CCD problems in consumer imaging productsCCD Sensor Problems in Consumer Imaging Products .... Given that the Leica DIGILUX 2 is a variant of Panasonic's Lumix DMC-LC1 design, it isn't surprising ...
www.imaging-resource.com/badccds.html - 51k - Cached - Similar pages
Posted on Feb 25, 2008
kakee
Michael Galve
  • 1269 Answers
SOURCE: The photos aren't downloading from
Make sure you have the Mac driver for your camera. Install the Mac driver that came with the CD. Try to use a different USB cable. You can also try to isolate the problem by plugging your camera to a Windows OS computer like windows xp and vista.
Posted on Sep 16, 2008
Ty Price
  • 11967 Answers
SOURCE: Hi, I have a Panasonc Lumix DMC TZ2 digital
Sounds like you lost the connection to the sensor.
Posted on Feb 22, 2010
Anonymous
SOURCE: Lumix dmc-ts1 will not turn on after taking underwater pictures
I had the same problem, half way through snorkelling the screen just went black and the camera wouldnt turn back on, HELP PLEASE!!!
Posted on Mar 07, 2010
White Screen. When I turn my camera on, it has power but, the display is white and you cannot see anything through the view finder.
hi,
did you check the picture through the view finder ? if it is clear, then there may be snag in the monitor, normally the connecting cable to the motherboard become break, if so should replace it.
if the picture is visible when you turn the monitor to either side, then you can confirm the fault of the cable.
Feb 26, 2016 | Canon Elura 100 Mini DV Digital Camcorder
Troubles Turning Camera On
What kind of camera is this? I suggest calling the company such who will take time on the phone and work with you to fix the issue. Didn't have the same problem but have a Nikon and they assisted me over the phone almost an hour working with me to solve the issue.
Mar 25, 2017 | Cameras
I haven't turned the camera on for a couple of years. I've tried charging the battery, but I can't get it to power up. Do I need to replace battery or is it something else?
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 06, 2012 | Samsung i85 Digital Camera
.HAVEN'T USED 10D FOR A LONG LONG TIME AND
Here are a few things to try:
1. Remove the main battery and the small backup battery (CR2025) from the battery compartment. Charge your main battery and put both batteries back in once your main battery has been charged. Sitting without batteries will give the camera a chance to reset itself.
2. You may have a bad CF card. Try starting your camera without a CF card or use another.
3. Try reloading the firmware (camera's operating system) using this link Canon. http://web.canon.jp/imaging/EOS10D/10D_firmware-e.html
Be careful to follow instructions exactly as restarting the camera in the middle of a firmware update will brick it and you will need to send it back to Canon for repair.
Hope that helps,
Bax
Oct 11, 2011 | Canon EOS 10D 35mm SLR Camera
Wont go to picture taking screen or playback menu
A lot of cameras seem to be having this issue (including myself). Eventually it got to a point where the camera doesn't even turn on properly anymore. Better take it back for repair, STAT before it ends up like mine :(
Jun 29, 2010 | Fuji FinePix J10 Digital Camera
FLASHES C:13:01
OMG!!! If you still have the camera, try this. I read in one of these forums to spray a burst of brake cleaner in there and blow dry for a few seconds and believe it or not, it worked! That's after me taking it apart to make sure the connectors weren't loose, using the pencil eraser and banging it. I am not making this up. It was my last resort and it worked. Good luck!
Dec 31, 2008 | Sony Cyber-Shot DSC-P200 Digital Camera
Canon A75 No startup sound & display on LCD, rest of things works fine
Think it might be your batteries. 700mah batteries are pretty weak by today's standards (most are at least 2,500 mah these days). I'm guessing your batteries are several years old? If so, they're really only meant to have a usable shelf life of a few years, whether they are used or not. Recommend trying a new set of rechargeable batteries.
Mar 20, 2008 | Canon PowerShot A75 Digital Camera
White pictures, low battery life, few pictures
I glued a small peice of plastic under the flash and above the camera lens to shade it from the flash when it goes off. I then only had 2 pictures out of 40 that showed a white picture. The plastic peice only sticks out about 1 inch and didn't affect the flash on the subject. I also drilled holes in the bottom and hooked up a 6 volt tractor battery to it this gave me over 1 month of battery life with another identical camera
Jan 21, 2008 | Moultrie MFH-DGS-200 Digital Camera
I can not take pictures
update, possible solution..
I pulled the batteries for 24 hours, attempting to force a reset of the camera. Today it worked, took pictures and zoomed just fine. I shut it off after about 10 pics and turned it back on and back to the start... Took the batteries out for a few minutes and put it back in and back in business. Hope this helps at least get SOME functionality out of it. This won't serve as a long term solution for me, but perhaps will lead towards a full answer.
Dec 17, 2007 | Olympus Camedia D-540 Zoom Digital Camera
Panasonic Lumix DMC-FS3 Digital Camera Logo
43 people viewed this question
Top Panasonic Cameras Experts
Ekse
Tom Chichester
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
