When iclose the lid and turn on the camera code c31 23 appears
SOURCE: C31-23
Sony says that reload the cassette. If problem still exist, contact nearest Sony repair shop. Its basically "Supply Reel Signal/ Function Error".
SOURCE: Sony TRV460 error code C31:22
try slapping it at the side of the tape and than maybe push the reset button, it must solve your problem, its probably the little lever inside that tells the camera that there is a tape inside
SOURCE: pd170 c31:98 error
The error C31:98 it means Mechanical position fault..here u have to check the adjustment of position and phase Gear
SOURCE: My sony camcorder flahses C31:22
You guys were right! I banged on my DCR-TRV 280 Digital8 and it's back working. Hallelujah!
SOURCE: Sony CCD-TRV15 reads C31:10 code
Please note that there are guide posts that are not supposed to be straight. At this point, the C31 message indicates that motor or gear that is not turning as it should. This unit should be seen by a service center for a re-alignment and timing check.
Dan
