SOURCE: MY MAYTAG REFRIGERATOR
remove back panel inside freezer and there is a tray at the bottom with a drain hole in the middle. this is blocked with ice. melt off with a hairdryer and follow up with hot water till it flows waay freely
SOURCE: water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
SOURCE: I have a Maytag Model MSD2456GEW/side by side
Most likely your defrost drain is frozen over due to a blockage in the defrost drain behind the rear wall of your freezer. Usually this is caused over a period of time or the refrigerator is leaning slightly allowing the water to slowly freeze over the hole. I will send you to a link where you can look over a collection of reasons, photos, video and a manual for your model. Click here=> LEAKING REFRIGERATORS Read over that and have a look over the service manual Here=> MSD2456GEW If you need to save a copy I encourage you to download the latest free version of Adobe Reader 9 here=> adobe.com If you should need me you may find me here at Fixya or here=> Appliance 911 If you still need assistance, contact me here at Fixya or through my site HERE or here Sea Breeze Appliance Parts feel free to ask any time, Sea Breeze
SOURCE: refrigerator side of a Maytag side by side refrigerator not cold
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
SOURCE: I have a side by side Maytag Refrigerator model
We had this model as well. It is part of the fridges 'defrost system' that prevents icing up in the freezer. I had replaced the computer chip in mine (at a cost of about 150 bucks), when at one point when it failed, and the freezer starting freezing over, and after it was 'fixed', it started leaking water onto the floor again. After another year, we finally bought another fridge. Solution... buy another fridge
