I need instructions for setting time zone
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Adjusting the Home Positions
If the time and date settings are wrong even after the time calibration signal is
received normally, use the following procedure to adjust their home positions.
To adjust the home positions
1. While in the Timekeeping Mode, hold down A and B
for about five seconds.
• The analog hands do not keep time during home
position adjustment.
2. Check the position of the second hand.
• The second hand home position is correct if it is
pointing at 12 o’clock.
• If the second hand is not pointing at 12 o’clock, it
means that its home position is off. If this happens,
press A to move the second hand clockwise in onesecond
steps, until it points at 12 o’clock.
• Holding down A for more than two seconds causes
the hands to move at high speed. Pressing A again
stops the hands.
12 o’clock
Correct second hand
home position
3. Press B to advance to hour and minute hand home
• If current hour and minute hand alignment is correct,
they will both move to 12 o’clock.
4. Check the position of the hour and minute hands.
• If the hour and minute hands are not pointing at 12
o’clock, it means that their home position is off. If this
happens, press A to move the hour and minute
hands clockwise in 20-second steps, until they point
at 12 o’clock.
stops the hands.
5. Pressing B exits the home position adjustment mode
and enters the Timekeeping Mode.
You can try this link as well.
type in 4303 as the module number and then download the pdf file.
I have a casio wave ceptor 4756 wvq-140a lost book on it I need to change it from mt to ct thanks
Http://ftp.casio.co.jp/pub/world_manual/wat/en/qw4303.pdf
You can find the manual here:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw4303.pdf
Read it carefully!
Manual found above fixed this same problem for me.
Thanks
Jeff Gilliland
SOURCE: instructions for casio wave ceptor 4303
Managed to set the home time - through trial and error.
Left it at the window for a few minutes and VOILA - the watch did the rest.
MAGIC!
It keeps time perfectly.
can not get the time set back from fat time
Can't switch out of DST.
I lost my instructions on my Casio Atomic Watch GW-300 and I cannot adjust my watch after the "fall back" daylight saving time ended. Can you give me the instruction?
I looked at the watch face and all the bottons and knew I needed help to set the cerrect time, Date, day
cannot change time
My problem is that this watch after I activate the time keeping mode dosen't adjust to the correct time after I scroll through and adjust the seperate modes. Who can help me?
how to adjust its day and day?
I have a wave ceptor 4303. Even with the manual I can't get it to set the correct time. It sets to about 3 hours and 40 minutes off. I even had the battery replaced, it still doesn't help. Anyone have a suggestion?
set time
Can't set the date on the watch
casio
setting time zone and daylight saving mode
i can not set the time
i have no users manuel and do not know how to set the time
