SOURCE: Front drain plug
I have similar issues with my Asko W660. Once it was a key stuck between the inlet to the pin trap and the trap itself. I got it out by jiggling and poking into the trap area with a narrow strip of plastic. Mostly, though, it just requires a stronger grip on the door to the pin trap--the little handle is slippery, and hard to get a good grip on. Try making a grip out of a piece of duct tape, or grabbing the handle with pliers.
SOURCE: Asko washing machine has no power
check your ground fault interupters (outlets with butons) under the sink and around the kichen
then check the breakers in your breaker box
finaly call a sertified tecnition
SOURCE: ERROR F3 - WHAT DO I DO?
hi the error shows bcoz of ur door problem...
replace the door lock and ur problem will be solved...
SOURCE: My Asko W6441 front load washer F3 message
Hello. You said that you checked the drain line for obstructions, but did you check the pump? I would remove the hoses from the pump and using a flashlight, look into the suction port on the pump. Check the pump for any obstructions (like the occasional stray sock) and check the pump impellers. Look for broken/missing blades and ensure that the impeller spins freely. If there are missing/broken blades or if you cannot get the impeller to spin freely, the pump is defective. You may have already done this, and if so I apologize. Anyway, hope this helped and best wishes.
