SOURCE: Miele Novotronic.
all miele are supplied with schematics. on washers take the top off and its on top of dispenser tray. if not there remove front panel it will be there
SOURCE: My Miele Novotronic W502 does not have any power although it is plugged in
I would check that I do have power present at the outlet. If power is present the next step would be to check the fuse on the push button switch. Unplug the machine and then gain access to the push button switch by pulling the knob off after that you will need to take the orange plastic key from behind the detergent dispenser, and use it to remove the facia panel by pressing down slightly and wedging the key in between to gain access to the electronic. The electronic can be removed by taking out the 2 Torx 20 screws one on each side after that remove the connector plugs from the push button and unseat it from the clip. If you the fuse has continuity it could be a problem with the interference capacitor or the electronic.
Turn the machine off.
Turn dial to finish.
Turn power back on.
Select drain and start.
When drained you can begin again.
