Question about Euro-Pro Shark GI490 Iron
Can i buy a fabric selector replacement button for my shark g1490. This part is used to select the various fabrics and sits on the handle just below the steam spray buttons.Reply to joamzima@gmail.com
6ya staff
SOURCE:
Anonymous
SOURCE: Shark Euro-Pro G1490
Our G1490 quit after one year. Just won't come on. Period. I can't get it to open after removing the back screws either.
Posted on Apr 26, 2008
Anonymous
SOURCE: Stopped producing steam
Iron not heating up sufficiently to produce steam. Threw it out!
Posted on Jun 25, 2009
Anonymous
  • 19 Answers
SOURCE: Brown steam bursts coming out of my G1490 Shark iron
make sure you do a self clean as often as possible to remove debris and scale from iron
Posted on Aug 16, 2009
bamajimbo
SOURCE: was using my Shark x-tended
I had the same problem. The repair took less than 15 min. I opened the bottom of the iron and discovered what appears to be a design flaw on the cord holder/fastener. The holder is wedged so tight that it pinched the cord wire almost in half. I removed the cord, cut it off at the pinched spot and reinstalled. I also put a small piece of rubber onto the part of the holder that is made onto the body of the iron. In addition, I rotated the fastener cap so that the smooth side of it is against the cord.
Posted on Feb 11, 2011
walesarumi
Walesarumi
  • 6993 Answers
SOURCE: My shark iron went into
There is probably a disconnection inside the iron that's why it won't light up. Usually, when the heating element get's defective, the won't heat.
If the iron has a three pin socket/plug, open the plug and check if the fuse is intact. If the fuse is intact, then it means you will have to disassemble the iron.
Check all the wire connection inside the iron, observe if you will find any disconnection of any kind. There are not much wire inside the iron, so I believe this shouldn't be difficult.
Have the iron checked by disassembling it.
I hope you understand the above......
Good luck.
Posted on Apr 17, 2011
I have a Shark Iron Model # G1490. The fabric select button broke off. Is there a way to get a new part?
no parts like that are not a stock item
for the price , junk it and get a new one
Nov 23, 2017 | Irons
HI, I DONT KNOW HOW TO OPEN MY SHARK RETRACTOR IRON, IT HAS 2 SCREWS AND I PUT THEM OUT....BUT THE PROTECTOR DOESN´T RELEASE....HELP
Right below the button that you press to select fabric is that black rubbery piece. Use a screw driver to pry it up and then remove the three screews holding down the rest of the retracter. Mine was getting power to the circuits so I trashed it. I won't ever buy this brand iron again has it did not last very long.
good luck
Nov 19, 2009 | Sunbeam 4039 Iron
The on/off fabric select button has broken. Where can I get a replacement. The switch works correctly.
I'm sorry, I could not locate the exact part you need, but try this link. http://www.sharkclean.com/cgi-bin/livew/site.w?location=olc/contactus.w&frames=no&target=main&sponsor=000001There is a number to a representative who could probably help you out. I hope this helps.
Oct 13, 2009 | Euro-Pro Shark GI490 Iron
Shark model G1490 won't heat. Can heating element be bad?
if lights are coming on its either the wire that send power to the heating element or the element itself
Jul 15, 2009 | Euro-Pro Shark GI490 Iron
I have a brand new Shark G1490. When I plug it the light turns on, but it does not get hot and besides this brown water comes out. what should I do? please help me.
push button down on top of iron to turn on iron and adjust settings and do a self clean to remove debris and scale build up from iron
Jun 11, 2009 | Euro-Pro Shark GI490 Iron
My G1490 Shark Iron will not heat up.
your heating coil probally went bad its alot cheaper tp just buy a new iron
Jan 18, 2009 | Euro-Pro Shark GI490 Iron
Shark G1490 doesn't light up or heat up when I plug it in.
circuit board has shorted out that control iron functions or power wire lead has broke off inside of iron
Jan 12, 2009 | Euro-Pro Shark GI490 Iron
Iron won't heat
send me manual on iron g1490
john reilly, 5640 hwy 14 w janesville wi 53548
asap
thank you
Aug 13, 2008 | Euro-Pro Shark GI490 Iron
Jan 08, 2008 | Euro-Pro Shark GI490 Iron
Euro-Pro Shark GI490 Iron Logo
204 people viewed this question
Top Euro-Pro Irons Experts
Bruce Showalter
Sheldon Dedek
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
