Question about Epic View 550 Treadmill
How do I adjust the Epic view 550 max spd pot on the controller?
Anonymous
SOURCE:
Anonymous
  • 40 Answers
SOURCE: How do you put the treadmill down?
There is a knob on the support bar behind the treadbelt deck. Give the deck a little push up, then pull the knob out and lower it.
Posted on Sep 29, 2009
maxtreadmill
John Mazmanian
  • 832 Answers
SOURCE: I left the red key in epic view 550 for 1 full
Check the reset/off circuit breaker located on the treadmill frame near the power cord. If the switch protrudes as shown, the circuit breaker has tripped. To reset the circuit breaker, wait for five minutes and then press the switch to the reset position.
Posted on May 06, 2010
JIm Shipley
  • 218 Answers
SOURCE: I put it "up" for
push it forward before trying to pull knob and make sure the incline is at the lowest level.
Posted on Aug 10, 2010
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: how do I change the motor drive belt on an epic view 550
Posted on Jun 18, 2012
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: Everything works except the Treadmill motor ? Incline works OK, belt doesn't turn at at all. Model EPIC View 550
1) You have problem with LUBE deck belt, this happen because the lack of maintenance, you must lube EVERY week, use 100% silicone lube. Maybe you have WORN deck belt,
2) LUBE the rollers bearing too, use wd-40
3) Test the drive belt motor, see for break, or worn, and replace or tension by 1/4"
4) Test the input voltage motor, if there are the motor need repair. see my personal TIPS for help and troubleshooting.
5) Test the output voltage board, for input voltage motor, if there are NOT the board controllers is faulty. God bless you. see the block diagram attached.
Posted on Nov 26, 2012
Epic 550 treadmill
If you wish to get some derails about treadmill repair then check the below added link
http://electro-medical.blogspot.com/
Jul 07, 2016 | Epic View 550 Treadmill
Why doesn't it start?
epic view 550 treadmill video 2 - YouTube
? 2:08
https://www.youtube.com/watch?v=fSIuoh_bZN4
Mar 9, 2010 - Uploaded by Epictreadmillowner
epic view 550 treadmill video 2 ... ICON Canada doesn't really support this and the independant technicians ...Epictreadmillowner 1,181 views.
Epic View 550 Treadmill Review - YouTube
? 3:02
https://www.youtube.com/watch?v=kNiFOcrV9r4
Nov 29, 2012 - Uploaded by Treadmill Review Guru
... .com/epic-treadmill-reviews/epic-view-550-treadmill-reviews-ratings/ ... Nordic track has the track and google maps by i-fit you can download and run anywhere ... The review says it doesn'thave the track/lap but it does.
Epic View 550 Treadmill video 3 - YouTube
? 1:59
https://www.youtube.com/watch?v=YjqgZS-1qlw
Mar 11, 2010 - Uploaded by Epictreadmillowner
Epic View 550 Treadmill video 3. Epictreadmillowner ... I have had 3 different console units, and now the tv doesn't work either!
Epic View 550 Reviews - MyTreadmillReview.com
mytreadmillreview.com/epic-view-550-reviews-2
Jan 27, 2016 | Epic View 550 Treadmill
EPIC VIEW 550 MOTOR WONT START
Please post the specific model # found on the model/serial# decal on the frame of the machine (EPTL....)
Who replaced the drive motor on the machine, and for what reason? Did the new motor ever function when installed?
Nov 24, 2013 | Epic View 550 Treadmill
Epic view 550 treadmill
RUN the software calibration, and test the machine
God bless you
Sep 28, 2013 | Epic View 550 Treadmill
Console epic 550 treadmill
adjust the REED swtich, test it for open or faulty, clean it , and tight the plug very well. see the diagram attached.
Plug the ribbon cable for keypads very well, and clean it.
God bless you
Dec 02, 2012 | Epic View 550 Treadmill
I am having trouble removing hood/motor cover on Epic 550 treadmill. I have removed 4 - 3/4" screws from front panel and 2 - 1/2" screws from underneath. Still feels locked on. Are there other...
If you lift your treadmill deck up, you will find 2 screws underneath, on the side, towards the front. remove them and that should do the trick.
Nov 23, 2010 | Epic View 550 Treadmill
I put it "up" for storage and now I can't get it down to use... Epic View 550
Aug 10, 2010 | Epic View 550 Treadmill
How do you put the treadmill down? We can't seem to unfold the treadmill. It's an Epic View 550. Thanks!
Sep 26, 2009 | Epic View 550 Treadmill
Epic View 550 Treadmill Logo
73 people viewed this question
Top Epic Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Colin Stickland
Colin Stickland
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
