I tried the guitar strings, they burned out quickly. The wires that came in the unit are not steel, they are not affected by a magnet. We suspect they may be tungsten or some other type of non ferrous wire. Until we find the right wire, we cannot repair them to last. Any assistance in locating the correct type of wire for use in ionizing air cleaners would be appreciated.
Did you ever figure out what wire and gauge it is? Thanks!
Thank you Rogar. I have 4 Quadras and the ionizer wires broke on all of them. Best air cleaners we ever had, they worked for many years. We have 3 table models, too, but I think the problem with them is in the transformers.
SOURCE: broken wire inside ionic breeze
Hi, actually the broken wire is nichrome and measures approx .00045 inch. Go buy a couple of .09 guitar strings from your local music store and use to replace it.....
SOURCE: ionic breeze quadra
If you are talking about the 2 thin wires inside the unit, it can be fixed if you are good with taking things apart. You have to do an almost complete tear-down of all the internal components (many hidden screws). You can replace the broken wire with a .009 or .008 gauge E string for an electric guitar. This can be found at a local musical instrument store. The string must be cut to almost the exact length. The wire has a spring tension mount on a small circuit board. If the replacement wire is too long, there will be too much slack, too short and you will not be able to put it back together. I did this and it took me hours. I removed about 80 screws to disassemble it.
SOURCE: Professional Series Ionic Breeze Tabletop
There isn't one. The reason why Sharper Image went out of business is because the Ionic Breeze was proven to be ineffective product and harmful to use in some cases based on Consumer Reports data as well as data from the EPA. They sued Consumer Reports, lost the case, and had to pay all the legal bills.
The Consumer Products Safety Commission is going to making decision on all ionizers by the end of the year. It's quite possible that no one will be selling them anymore.
There is thread I left in the Ionic Breeze section about the EPA data on ionizers and the harmful effects of using them as well as a link about what happen to Sharper Image.
This product should have been regulated a long time ago. Orek and few others are going to be pulling the plug on them real soon.
SOURCE: Ionic Breeze Quatra Hissing Noise
While the device is turned off and the filter is out, tip the unit itself upside down and back. Do this several times, there is a slider type cleaner inside that moves as you turn the unit. Be sure to do this every time you clean your filter and you will never hear a peep out of the thing.
