Question about Samsung Galaxy Tab 2 7.0
My tablet won't charge - Samsung Galaxy Tab 2 7.0
    Top Expert:
  • Samsung Master
  • 11,573 Answers
Tablet won't charge
Posted on Jul 01, 2016
    Spread the Word:
    An expert who has shared 5 answers on their Facebook wall.
    New Friend:
  • 36 Answers
That might be caused by a failed hardware inside your device, you can open the device and at the back in there is a power charger strip, that is what you need to consider playing round with, either it is loose or you need to replace it. Have find discovering.
Facebook
Posted on Oct 12, 2014
    Novelist:
  • 210 Answers
Frequently, a "won't charge" scenario can be traced to the "charger" rather than the item to be charged. Every power source has it's electrical requirements either imprinted directly on it, (usually on the side with the prongs), or on a sticker somewhere on the surface. It will spell out the input and output requirements of the unit. The input should be 110/120 volts AC, and the output should be from 1 1/2 to 2 volts, DC more than the required voltage to run the tablet. That little extra voltage is necessary to "PUSH" the voltage into the battery. If you had a charger that put out no more than the 9 or 12 volts it takes to run the tablet, it would be at a standstill when trying to charge a battery of the same voltage. If you don't have a volt/ohm meter available take the charger to someone that does and ask them to check it's output rate. If it's in the range I mentioned before then the charger is good and it is the battery that's bad.
Posted on Jun 15, 2014
    New Friend:
  • 4 Answers
Are you saying that when the tablet is plugged in, it works, but it won't hold a charge, or is the problem that even when it is plugged into the charger, the tablet will not power up? That is the most likely symptom.
If that is the case, most likely, you have a bad charger cable. These go bad if they get flexed too much. You can find replacements on EBay at a reasonable cost.
if you do have power when the tablet is plugged into the charger, but not once you disconnect, then you probably have a bad battery. Replacing the battery can be done, but requires opening the tablet, which is not so easy.
6ya staff
SOURCE:
Can I buy a power cord that charges while you are using the tablet?
all tablets can charge while you are using them, on rare occasion the battery will completely discharge and will need to be charged to the minimum before operating the tablet.
Feb 06, 2016 | Hipstreet Flare 2 9 inch Tablet with 8GB...
Mid model m729b
I have similar problem, my buttons on the right side including yjr start button have slipped inside the case and I can not restart the charged device, Can you help?
Pat Green, pgrex@hotmail.com, 409-782-2572, thanks if you can help.
May 07, 2013 | mid Archos M729B Android Tablet
7" touch andoid tablet won't charge
It may be the charger has a loose wire. In that case a new charger would fix the problem. Mine has a problem with the charging port itself. I am fortunatly that my tablet is under warrenty they are going to replace the tablet for me.
Dec 27, 2012 | Nextbook Premium 7 Capacitive Touch...
AC adapter/charger is attached, but the battery will not charge. it doesnt even show that the battery is there
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 21, 2011 | Toshiba Portege M200-S838 Tablet PC
Samsung Galaxy Tab 2 7.0 Logo
111 people viewed this question
Top Samsung Tablets & eReaders Experts
Eric Rotmil
Eric Rotmil
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
