Not making ice
SOURCE: Kenmore refrig not making ice and top shelf area in refrig not cold
if you are having tempurature issues make sure the fan in the freezer is operating. it should be on when the compresor is running. this may explain both warm fridge and no ice.
SOURCE: No ice from icemaker of Kenmore Elite model 106
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with this miracle fix of using a hair dryer to melt the frozen water line going to the dispenser output. This is highly unlikely for our model since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't enough water pressure to trigger the solenoid valve. $40, and still no luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage going to solenoid, so I wasted $30 for a new solenoid.....still no water.
-4th thing was I ordered a new IR sensor and receiver (since the reciever end is where the relay that sends the voltage to the solenoid to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch underneath the freezer unit and disconnected, and removed the freezer unit to inspect it further.
When I removed the protective white cover that covers the mechanical wheel, I had a few parts come flying out of it. Turns out that the wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48 BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10 times it will fix your problems. All techs replace the IR set at the same time too which will set you back another $58 bucks.
Good luck! ;)
SOURCE: Icemaker leaking causing icicles
Is it overfilling with water? If so, it may be an problem with the fill valve leaking slightly. I say slightly because if it were a large leak, the freezer would have frozen puddles in it. Also check the water chute to be sure the water is all going into the freeze tray. Sometimes they can work loose.
If the seam is leaking, there could be a crack in the housing - not sure that's repairable - sometimes epoxy will work (5 minute, 2 part) but it can be difficult for glue to hold on the type of plastic used in an ise maker housing.
SOURCE: kenmore icemaker does not work
Hand drawn of the GE # WR30X1009 found in 10-12 yr old Kenmore/sears/GE side by side refers. Couldn't find one ANYWHERE so forgive the hand drawn. Mine would not eject ice, intermintant. Bad microswitch on the on/off/vacation mode between the normally open side.
SOURCE: Water not going into icemaker. Water dispenser works fine.
Check the water valve at the back of the fridge if present.
Even if you used blowdryer, ensure that linse are not frozen by performing a complete defrost.
Disconnect water lines from icemaker, and blow with compressor if the above did not work.
