Kindle entirely depends upon WiFi to access the internet. Following are the few simple tricks you can try one by one to fix the Kindle Won't connect to wifi error.
Refresh the Kindle Device
Switch Router
Distance of Router and kindle
Must select the 1-11 channel
Connect your kindle with the 2.4 GHz band
Try re-checking your wi-fi password. Log off your connection, Then try again to log-on. Make sure you have the right service, put in info and see if it takes. You may have to try a different service to see if the problem may be their's. If you logged into a different wi-fi recently you may still be logged into that one even though out of their range.
sounds like you did everything right
could call amazon see if they can help
or do a factory reset to eliminate software problems you will lose all your data
then there is hardware problems dead battery that won't recharge bad cable connection inside kindle
you need to go to your amazon acct,verify that you have money,then look for the book and buy it,if that doesnt work,then look for contact us on the amazon page and clik on it and tell them what the problem is,you may have deleted everything or someone took everything out of your acct,DO NOT give your acct password to anyone,only use trustworthy ppl to help you,if someone hacks your acct,then change your password and complain on the site it happened on,kindle tech support, http://www.amazon.com/gp/help/customer/display.html?nodeId=200317150
This will turn on the Wi-Fi transceiver. In the Wi-Fi Networks section right below the Airplane Mode section you will see available Wi-Fi networks. Click the little black triangle, choose your network and enter the password. It will only automatically connect to open networks. Most networks these days are *secured* and need a password in order to share data.
