When the container light is on, the container is removed and cleaned and runs for 30 minutes then the empty out container flashes again
SOURCE: the empty container/pc light comes
at the back of the dryer there should be a plastic tube from top to bottom ( this is the overflow pipe from the water container that needs to be emptied after each use, if the container is allowed to fill up, the water gts picked up by this pipe and collects at the base of the machine, stupid idea, i know) undo the clip at the bottom and empty the tube, also, with the tube still of, tilt the dryer and if loads of water comes out where u disconnected the tube you just need to get the water out. re connect the tube and bobs your uncle. hope this helps. p.s u may want to remove the top cover ( 2 screws ) and blow down the tube to make sure it aint blocked. when re fitting the tube, dont be scared of bending it to get it back into the slot where it tucks into the machine
Testimonial: "thankyou very mutch, this was exactly the problem. i have done what you told me to do and that has cured the fault. thanks again. charles."
SOURCE: Anti crease light flashing, keeps stopping and beeping
Check the dryer vent to see if it is free and clear.
