I just change out my TV. I want my to be be controlled by the dis network remote control
SOURCE: remote control code/daenyx tv/dvd combo
Your TV is made by Daewoo and is distributed by Daytek. If you call the 800 number on the warranty card you will reach Daytek.
So, what you need to know is this:
#1. A lot of new products won't have a website available. That does not
say anything to their quality or the company, just that you've bought a
new product and you're one of the first purchasers.
#2. A lot of times if you buy a "no name" TV, you're actually getting
components inside the TV that are made by brand name manufacturers. For
example, "Prima" uses LG panels in some of their plasma TVs (as well as
Daytek). How do I know this? Because I'm the authorized service
provider for Daytek, and Prima and quite a few other "no name" TVs, and
I've been working on LCD and Plasma since they came out, as well as
having worked in the electronics repair industry for over 20 years. I
own an Insignia 42" LCD and am quite happy with it.
#3. Most new products that have remote controls will not have codes
available for them no matter what brand of universal remote you buy.
You have to wait for the people who make the universal remote to have
time to make a code for this new brand of TV. This can take up to a
year for cable companies, and cheaper universal remotes may never get
the code. Expensive universal remotes may be able to have their
firmware updated through the internet, so adoption of new codes for new
products may happen faster.
#4. Stores like Walmart and Costco are excellent places to buy products
like this because they usually have a "no questions asked" return
policy if you get the TV back to the store within the stores time limit
for returns (some stores are 15 days, some are 30 days, phone the store
and ask them). I had purchased a 40" Digistar LCD TV from Walmart what
had a flickering problem, I took it back the next day without any
problem at all. Then I bought a 42" Insignia Plasma TV from Future Shop
that I wasn't happy with. I took it back 3 days later and had no
problem at all. As long as you know the stores policy for returns and
follow the policy, you won't have any problems either.
#5. Try to avoid buying big-ticket items from smaller stores unless you
know their return policies. Some smaller stores will not accept returns
on LCD monitors, TVs or plasma TVs but instead require you to
handle any problems through the manufacturer.
#6. Best bet it to call Daytek and ask them if they know of any universal remotes that work on that particular model.
SOURCE: RCA Universal #RC402A
Programming Your RCA Universal Remote.
The RCA universal remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: TV-000, VCR-000, Cable Box-000, and AUX is programmed with VCR code 037. For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search: 1- Manually turn ON your device (TV, VCR, Cable Box) 2- Press and "HOLD" CODE SEARCH 3- Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once. 4- Release CODE SEARCH. 5- Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second). 6- Once the device turns off, press and release ENTER. 7- With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists: 1- Find codes for each device and brand below. 2- Press and "HOLD" CODE SEARCH. 3- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step. 4- Enter the three digit code from the TV, VCR or Cable Box code lists. 5- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists. TV Codes Admiral 005 MTC 011,019,027 Amtron 064 Multivision 081 Akai 002 NAD 018,023 Anam National 038 NEC 011,014,019,027,038 AOC 011,019,027,088 MTC 0017,0023 Bell & Howell 005 NEC 0017,0023 Candle 011,027,033 Panasonic 012,013,038,086 Citizen 011,027,033,064 Penny 000,008,011,019,027,068,086 Colortyme 011,027,084 Philco 006,007,010,011,013,016,019,027 Concerto 011,027 033,035,037,038,043,087,089 Contec/Cony 036,037,040,042,064 Philips 006,007,010,011,013,016,033,035 Craig 064 037,038,043,066,073 Curtis Mathes 000,011,015,027 Pioneer 011,027,045,062,093 CXC 064 Portland 011,019,027 Daewoo 011,019,027 ProScan 000 Daytron 011,027 Proton 011,027,037,072 Dimensia 000 Quasar 012,038,092 Electrohome 006,011,014,027,038 Radio Shack 000,021,025,036,037,059,064 061,068 RCA 000,006,011,019,027,034,038,044 Emerson 011,026,027,028,029,030 046,088 031,032,037,042,053,064 Realistic 021 065,067,075,076,079 Sampo 011,027 Envision 011,027 Samsung 006,011,014,015,019,027,036,037 Fisher 017,021,039,041 077 Funai 064 Sanyo 017,021,039,056,057,058 GE 000,008,009,011,012,027 Scott 028,037,064 038,068,086,089,091 Sears 000,006,011,014,017,018,021,023 Goldstar 003,004,006,011,019 027,039,040,041,051,071,083 027,037,050 Sharp 011,020,025,027,037,052,053,059 Hallmark 011,027 060 Hitachi 009,011,027,036,037 Signature 005,094 040,047,048,063,080 Sony 002 Infinity 013 Soundesign 011,027,033 JBL 013 Sylvania 006,007,010,011,013,016,027,033 Jensen 011,027 035,043,049,066,087,089 JVC 012,024,036,037,040,048,051,074 Symphonic 064,076 Kawasho 002,011,027 Tatung 038 Kenwood 006,011,014,027 Technics 012 Kloss Novabeam 035,043 Techwood 011,027 KTV 078 Teknika 011,019,027,033,037,040,066 Loewe 013 Telecaption 090 Luxman 011,027 TMK 011,027 LXI 000,013,018,021,023,054 Toshiba 018,021,023,071,085,090 Magnavox 006,007,010,011,013,016 Universal 008,009 027,033,035,043,066,087,089 Victor 051 Marants 013 Vidtech 019,027 Marantz 011,013,027,069 Wards 000,005,006,007,008,009,010,011 Memorex 005 013,019,025,027,028,035,043,059 MGA 006,011,014,019,022 066,076,082,089 027,041,056,061,068 Yamaha 006,014,019,027 Mitsubishi 006,011,014,019,022,027,041,055 Zenith 001 056,061,068
SOURCE: I HAVE RCR312W REMOTE AND NEED CODES FOR PHILIPS TV .
0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0081 1149 1154 0288 0456 0003 0008 0068 0075 0086 0087 0141
SOURCE: instructions on how to program RCA universal remote control
This link is a .pdf of the manual with directions on how to program the remote as well as all of the codes for various electronic brands for all equipment (DVD, TV, VCR, etc.):
http://www.lexrixa.com/vcr%20codes.pdf
SOURCE: remote control codes
Just ask at http://manualfox.com/remote.htm
- they find you every remote code. Send them model #s of TV and remote!
It would be our pleasure to help you with getting your DISH Network remote to control your Insignia TV. We're going to start by pressing and holding the TV button located on the top of your remote until all mode button back lights come on, and then release. Use the number buttons to enter the codes for your TV; here are some of the codes we currently have: 834, 538, 720, 000, 834, and 697. Press the pound (#) button. To check that the code works try several different functions on the remote to make sure it will properly operate the TV. Remember that some codes may not be compatible with your equipment. If this is the case, try the other codes listed for your Insignia TV until you find one that is compatible with it.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
