Drum makes noise when spinning shut down while washing house lights blinked and lights went out on washer. It was turned off and restarted and while in spin cyle drum made noise
SOURCE: Maytag washer will not spin
If your washer does everything but does not spin, it is your outlet filter which is blocked. Locate this and clean out, it has to work fine. Refer user's manual.
SOURCE: Maytag Washer Noise While Spinning
Most washer models have snap-clips holding the front of the top panel down, with hinge-like clips at the back. Carefully pry up the top panel on the front of the machine using a tool that won't scratch the finish, such as a plastic or wooden wedge. If it does not pop loose fairly easily, then carefully examine the back of the machine to see if this is a rare model that has screws holding down the top panel. (But really, it _should_ just pop loose.) Once the top panel is tilted up to expose the inside, you should be able to see everything you need to see inside the body to evaluate a spinning drum problem.
SOURCE: Neptune washer load noise.
I do know there is a set of bearings on the drum drive shaft. There is an inner and an outer. Some places mention that these bearings are no longer available. However, I found on ebay a gentlemen who sells these bearing and the seals in a kit for about $80.00. It comes with instructions on how to repair and will save a lot of money. I have done this once already to the same washer, now I am doing it again. If you search on ebay maytag neptune parts you will find his listing for a bearing kit. He also describes the jet engine noise.
SOURCE: Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
SOURCE: BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
