Sansui HDLCD3210 32 in. LCD TV Logo
A
Anonymous Posted on Jun 16, 2014
DVR IS SUPPORTING SANSUI VGA WHERE AS TV IS RUNNING
2answers
ComI have connected my laptop to Sansui 32 inch LCD through VGA cable but the i am not getting the notebook screen displayed on tv continuously. the screen gets displayed for a second and goes off, it is...
You may need to enable the notebook VGA output. They can switch between notebook only, notebook + VGA or VGA only. You usually press the "fn" key and one of the Function keys at the same time. On my laptop, I press "Fn" and "F5". Please note that it can take some seconds for the switching to be completed so press them together once and then wait 10 seconds to see if it does what you want. (remember it may be something other than F5, look for a picture of a monitor or a square symbol).
4helpful
2answers
I need a remote code for my tv for a comcast remote i have a sansui tv thank you
hi,
Try the following codes
5 digit code :- 10463, 11409, 11904, 11911,11935 (Comcast Universal Remote )
4 digit code :- 0463 (COMCAST - CUSTOM DVR-3 DEVICE UNIVERSAL REMOTE CONTROL)
ok
I have a vga cable hooked to my sansui tv and to my laptop, but the tv just says "no signal". What do i need to do?
you may need to change the resolution of the desktop it may not be correct for the input that the tv needs. also look for any buttons on the laptop that will switch the video over to the VGA output. i suggest tryin around 600X800 and see if it will show up. good luck
1helpful
Just installed a sentient 250gb cctv dvr system, cannot get the dvr box to display on tv even with specific cable bought from maplins and hdd light is flashing...help
By default it goes to VGA port out of the DVR.
So you could hook up a pc monitor to it and use that. Once logged in you can change to tv out via the desktop menus.
It is also possible to hold down a button on the DVR (cannot remember which one sorry) at DVR power up to switch it to use tv out instead of vga.
Dec 30, 2010 • Cameras
The model number for the remote is Sansui DVR 810
Try this website 1-800-Remotes Factory Original.Use ur DVR box as the serial number.They have everythings link to TV- VCR-DVD,and more all remotes.
1helpful
2answers
Trying to program my sansui tv with the cablevision remote control. unable to find codes
You have to do the universal way which involves:
1) turn on tv and dvr
2) press tv button + select, hold till the io button stays lit (5seconds)
3) once io button is lit, press up and down channel buttons and flip through them until the tv turns off.
4) press mute, this should turn the tv on.
5) press tv button to save the settings (turn off tv)
How do use a sansui hdtv as a computer monitor. I've already hooked up the vga cord. but I need step by step instructions of how to set it up with my remote
If you are trying to get your remote to control your computer, that will not work. The remote for your Sansui will only run the TV.
1helpful
I want to set up my sony vaio (vgn-bx567b) vga external display port to my sansui dft275 27" tv
if the tv has the correct input just plug it in and switch the tv input. if thers no input its kinda tricky,youll get horrible resolution
20helpful
4answers
Programming Device Control code for Memorex MVT2135B
21479 is the Sansui code that worked for me with the Memorex TV/VCR combo MTVT2135 and the Comcast Custom DVR 3 Device remote.
Top Sansui Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
