Craftsman 16 HP 42 in. Deck
You did not finish the statement about without the blades but if your saying what I thing you are...Ah Oh Sounds like you may have a bent crank..Did you hit something with the blades...take the belt off and start the motor..and Check for wobble of the V drive there should be NONE if it does it could be bent itself or the crank...good luck
SOURCE: i need belt diagram for 42 in deck
You can go to the Sears website an download a free owners manual that shows what you need.
SOURCE: I need a diagram on how to replace a 42
Follow this link to Sears parts site put in your model number and you might be able to find it there.
http://www.searspartsdirect.com/partsdirect/index.action
SOURCE: Sears Craftsman riding mower V belt getting chewed
I believe you may have the belt over one or more of the belt retainers next to the pulleys. They are 5 or 6 inches long and about a 1/4 inch in diameter. You have to loosen them when you put the belt on then adjust them to where they are just barely touching the back of the belt. They keep the belt from jumping off.
SOURCE: 20 hp 42 in. Deck Lawn Tractor - CA Model: can you give me a diagram for a craftsman mower de...
i have a 16.5 hp with a 42 deck for some reason one blade cuts alot lower then the other is there a way to adjust thanks
