If you have a specific zoom lens on and it will take shots in MF manual focus but wont in AF auto focus you could have a broken ribbon connector in the lens. Try with another zoom lens if you get the same problem it could be the camera. If it works OK then the ribbon in the affected lens may need replacing.
SOURCE: Trouble downloading
Are you connected to the PC? If so it is processing the download, thus it is busy working.
SOURCE: Busy message when trying to take picture with
This happens only after you take outdoor night shot at low ISO(and more if RAW +JPG is set) .It will take long time to process this and store this(and longer with a cheap card)
SOURCE: my canon t1i rebel does not take pictures and says its busy?? wha
In the manual mode, you have to set the focus (distance to subject), aperture and shutter speed. Did you set all of them before you shot the picture?
SOURCE: Cannot use the screen to view on Canon Rebel T1i
I wish you know that you need to press LIVEVIEW button marked red Dot to enter live view mode.
Further more it will work in P,T,A,M modes and video camera modes only.Still it does not show live view the camera has a fault.
If this has solved it don't forget to rate me.
SOURCE: Canon EOS Rebel T1i won't take a picture when I zoom
Which mode are you on? When you zoom in, the maximum aperture size decreases to f/5.6 in the kit lens. Sometimes it may be too dark or shutter speed too slow so the camera doesn't shoot. If you're in "P" (program) mode, full auto mode or any of the Basic Modes, the aperture/shutter is auto. In other modes (Av, M, etc) you can turn the dial on the top of the camera to adjust shutter speed to a lower number.
check whether the lens connecting point is sticky(not getting spring action)give a little cleaning liquid on all contacts often press it until it release, clean the lens's contacts also.
