The drum keeps rotating but clothes do not dry. I have already changed the vent hose but that did not help. Any suggestions?
SOURCE: amana dryer model #LG4309W doesn't heat up like it used to
if it takes that long to dry your stuff then you have eather a bad blower wheel or the vent duct is stopped up ,,,, pull the vent hose off back of dryer and run a load and if it drys as should then clear the vent from dryer to outside of home ,,, if it doesn't then the blower inside the dryer is the problem / larry
SOURCE: Amana electric dryer model LEA30Aw will not heat
The heating element measures 10 Ohms at 68 degrees farenheit. Usually if the element is bad, it will measure infinity.
SOURCE: no heat, dryer exhaust vent cleaned, still no heat, gas line is on
I think you have a gas dryer, and a bad ignitor.
SOURCE: AMANA LEA60AW ELECTRIC DRYER, DOES NOT DRY CLOTHES FULLY
Your heating element is dying. A new element runs 'bout $40. It'san easy fix. Couple screws .
SOURCE: Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
