SOURCE: LG Model: LWHD1500ER - I
You can but the unit will have not control over temperature, and you can cause the unit to freeze up or slug the compressor w/ liquid refrigerant causing premature compressor failure. I would recommend replacing the thermostat if it is not holding proper temperature, but if dead set on bypassing it use a volt/ohm meter after unplugging it to find the normally open contacts and wire those wires together taking into consideration that the fan must run constantly with the compressor.
