Question about Zhone Computers & Internet
Port forwarding and pasword
6718
I can't find how to take the water out of the Bonaire QuieTECH BDQ24?
There is a smoked glass reservoir on the front, or you can set up a drain hose on the back to a sump drain.
It is mentioned on the right side of the manual
https://data2.manualslib.com/pdf3/68/6718/671790-bionaire/quietech_bdq24.pdf?7dff91db5df3f29962af89396f8cf267
Jun 24, 2018 | Heating & Cooling
Change pasword and name admin
its pretty easy, log in and go to admin tab
if you don't know the username and password to start the hold in the reset buttons until all the lights flash at the same time a couple times and then let go.
now the username and password are admin and password and you have lost all settings that were in your router such as wireless SSID and password, port forwarding, and static ip's... should have mentioned that 1st ;}~
Sep 16, 2013 | NetGear N150 RANGEMAX 150 Wireless Router
1045-1090-6246-8353-3166-2968 serial number 0453-2181-8558-7156-6718-7494-4063 activation number Normal: 194:13 activation type
serial number 1045-1090-6246-8353-3166-2968
activation number 3128-9632-0546-6153-2851-5366-4063
Normal: 194:13
send me autorization code
my email address
noumanraza_malik91@yahoo.com
Apr 08, 2011 | Adobe Computers & Internet
LINKYSYS HOOK UP
connect ethernet cable of your computer lan card to ports on linksys router ethernet port.
then acee in browser tis link
http://192.168.1.1
then username is admin pasword also admin.if not login then try username blank and pasword is admin
then set dynamic ip adreses enable .asl oset in your tcp /ip properties in lancard.set it to obtained dynamic ip aderss auto.aslo make sure in link sys that dns also automatic geting from isp.
thatys it.
u get INTERNET NOW FROM YOUR ISP.
Oct 25, 2008 | Linksys Wireless-G WRT54G Router
Sandrew
http://192.168.1.1
thatys it.
Oct 23, 2008 | NetGear WGR614 Wireless Router
How do i connect up my linksys
http://192.168.1.1
thatys it.
Oct 11, 2008 | Computers & Internet
Password help!
Enter the security code using your Kenwood remote. For the DDX6019
The key sequence to enter the security code KCAR : on the side of the remote there is AUD, DVD,TV. now enter 55 in the AUD then go to DVD and enter 2 which is fast forward then go back to AUD. Do the same for the rest.
5
5
fast forward
fast forward
fast forward
7
7
fast forward
Aug 17, 2008 | Kenwood DDX-6019 Car DVD Player
Rca cable modem...
This one is for a DCM 315, it should be pretty close and might work. http://a1212.g.akamai.net/7/1212/6718/20030131/comcast.download.akamai.com/6718/help/cmdrivers/RCA_315.zip
Jun 20, 2007 | RCA Cable Modem DCM315R (11603540)
Port Forwarding
To Enable Port Forwarding for MR314 or RP114 1. Type the router's address in an Internet browser's address bar. (By default the router's address is 192.168.0.1). 2. Enter the router's username and password. 3. Click Advanced > Ports on the left menu bar. 4. Enter the first port number in an unused Start Port box. 5. If only one port number is to be forwarded, enter the same number in End Port. To specify a range of ports, enter the last port to be forwarded in the End Port box. 6. Enter the IP address of your local server in the Server IP Address box. 7. Click Apply.
Feb 19, 2006 | NetGear MR314 802.11b
Port Forwarding
Feb 19, 2006 | NetGear RP114 Router
Computers & Internet Logo
29 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Joe Goldman
Joe Goldman
Mike
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
