I have the e64 error even after reset and I have replaced the heating element.. what do I need to do now?
Good Afternoon Friend,
I understand you are receiving an E64 code on your Electrolux dryer, model# EWMED70JSS, and want to know what it means. What this is stating is that there could be a possible issue either with the heating element or some wiring. It could also be a possible false error code. I suggest resetting your dryer, by either unplugging it or shutting the power of at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
SOURCE: frigidaire affinity electric dryer says error E 64, what does that mean?
Heater has an open circuit and need to be replaced. Here is the part you need.
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: I was drying and the
Hi
Error code E64 means Heater Open Circuit. This error appears when the Heating element or wiring to the heating element is defective. To clear the error code (s): Press and hold the far left key under the display and “cancel” buttons simultaneously for 3 seconds. If the error appears again then you’ll need to check heater coils and connections for open circuits. Use a multimeter to check the heater element, use Rx100 setting on the multimeter. It should display 30-33 K ohms as the resistance. If it is less than this or exceeds this limit then the element has gone bad and you would need to replace the element. Hope this helps...
Daniel
Hello cordiapartin - Typically error code E64 indicates that the dryer has detected that the heater circuit is open. Contact a professional to move forward accurately to check the heater coils and connections for an open circuit. Depending on the diagnosis's, the heater might need replacing and/or wiring
Hi gordsxbstn34 - Typically error code E64 indicates that the unit has detected that the heater circuit is open. Contact a professional to move forward accurately to check the heater coils and connections for open circuits. Depending on the diagnoses heater might need replacing and/or wiring
