Question about Behringer C-1 Microphone
Losing power in my microphones after 2 minutes of recording
How can I record outgoing message?
Recording your greeting
message
1 {MENU} i {#}{3}{0}{2}
2 {V}/{^}: "Yes" i {SELECT}
3 After a beep sounds, hold the
handset about 20 cm (8 inches)
away and speak clearly into the
microphone (2 minutes max.).
4 Press {STOP} to stop recording.
5 [off]
Feb 14, 2016 | Panasonic KX-TG6531B Digital DECT 6.0 1X...
Tip
How to record Guitar sound on a computer
<p>Line-in <br /> <p>1. Buy a software package for recording music, if your budget allows. Recording music software is specifically designed for recording musical instruments formed. He cannot offer features found in common software audio. Alternatively, an audio recording program for free to get the music recording software than your needs and budget. <br /> <p><br /> <p>2. Buying a guitar cable to your computer if you use an electric guitar. Connect the larger end of your guitar amplifier and the small end into the computer microphone / line-in. <br /> <p><br /> <p>3. For an external microphone when a traditional guitar. Plug the microphone into the computer microphone / line-in. A stereo microphone is a natural sounding audio file, due to the dual microphones. <br /> <p><br /> <p>4. Open your audio recording program, which recognizes the device connected to ensure the microphone / line-in. Pull the cord, again if it does not recognize the device. Change the settings for the recording program to your needs to adapt, you can file type for quality change, and the recording is mono or stereo and audio level. Press the Record button, then started playing guitar. <br /> <p><br /> <p>5. Press the "Stop" button when you finish the game. Some programs can automatically be prompted to save the file; others may be the audio file first. Press "control" and saving "S", if not prompted. <br /> <p><br /> <p>Digital recorder <br /> <p>1. Buy a stand-alone digital recorder, if you do not want a guitar cable or an external microphone. A stand-alone digital recorder is small enough to fit in your pocket and can be placed anywhere without the need hampered by a cable. <br /> <p><br /> <p>2. Set the digital recorder on a flat surface. Press the record button. <br /> <p><br /> <p>3. Press the digital recorder, "Stop" when finished. Connect the recorder to the computer with data cable. Open the device by clicking on "Start" then "Computer" and double click on the recorder in the "Removable Devices". Copy the file from the recorder to your computer. Turn off the burner when you are ready to save battery power.<br />
on Jun 21, 2011 | Computers & Internet
Hi i have a Tascam DP01FX which is showing error code 4 ,can you tell me if i can fix this problem and if i have lost all my work please cheers paul
The hard drive needs to be reinitialized - this will lose anything recorded on it.
With the unit off, hold down Track Edit and Shut Down at the same time while turning on the unit. It will ask "Are you sure?" press enter if you are willing to lose everything on the recorder. Continue through the rest of the prompts.
Mar 15, 2011 | Tascam DP01FX All-In-One Recording Package...
I have a Toshiba Laptop PC. It is a Satellite Pro L300 Series. I wonder if it has a built in microphone so that I can add a voice/music clip to my power point slides. I do not have a separate...
Most laptops do have Microphones built in. I do not know for definate that your laptop does, but you can easily test it to find out.
1. Go to the volume control (double click the speaker icon near the clock on the taskbar), go to recording properties and select microphone as the recording source and set the slider to about 80%.
2. Bring up microsoft sound recorder (its in the start menu somewhere) and click record... when you speak you should see a voice print appear in the sound recorder window.
If you do not see a voiceprint, then you probably dont have a built in microphone, but if you do see a voiceprint as you speak then you do have a microphone built in and you can record into your powerpoint shows to your hearts content.
Hope this helps!
Aug 18, 2010 | Toshiba Audio Players & Recorders
I plug my rode ntg-2 into the computer and record using audacity and the recording is extremely low in volume.
This mic needs phantom power to operate. Best bet, go and buy a USB mic pre, such as a M-Audio product.
This mic, I believe also runs on a battery, when phantom power is not available...so check the battery.
Or, simply, your record levels are set too low.
May 20, 2010 | Rode NTG-2 Professional Microphone
Tascam DP-02 is not power up.
you can buy a replacement power supply from here
http://www.audio-depot.com/index.php?main_page=product_info&products_id=2427
Sep 15, 2009 | Tascam DP01 All-In-One Recording Package...
Change from PAL to NATSC
hi there...try this
1. turn mic off
2. press and hold 8, then press power button (to change to NTSC)
press and hold 9, the press power button (to change to PAL)
Mr. Sean A. DelCarmen
Customer Service Dept.
In A Jiffy Ent. - Wow Magic Sing
1081 EDSA Balintawak
Quezon City 1106 Philippines
customerservice@magicmic.com
Mar 02, 2009 | Magic Sing Along Consumer Microphone
I can't remember how to record my outgoing message ?
here you go...
message
You can record your own greeting
message (max. 2 minutes and 30
seconds). If you do not record a
greeting message, a prerecorded
greeting message is used.
1 {MENU}
2 {V}/{^}: “Answering devicei
{OK}
3 {V}/{^}: “Record greetingi
{OK}
4 After the handset beeps, speak
clearly about 20 cm (8 inches) away
from the microphone.
5 To stop recording, press {OK}.
6 {OFF}
If this helps you solve it, plz rate this fixya. Thank you kindly.
Feb 01, 2009 | Panasonic (KX-TG1032S) Phone
Re: Tascam dp-02 8 track digital recorder been using for over a year no problems and having fun right up to today ... was adding a track to a song when i did a "punch -in" with the guitar (which i have...
It happens all the time to me. Only solution is to save constantly as you record because once it freezes up and says not stopped you can only unplug and plug back in then turn power on. You will lose what you were recording but nothing will be lost that you have saved.
Jan 19, 2009 | Tascam DP01 All-In-One Recording Package...
Behringer C-1 Microphone Logo
41 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Rob Beech
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
