I try to download Adobe Flash Player 9 ActiveX.exe and keep receiving this error message:
Error box titled: Adobe Flash Player 9 ActiveX Setup
red circle w/ white X inside. Error opening file for writing
CWindowssystem32MacromedFlashFlash9d.ocx
Click abort to stop installation
Retry to try again, or
Ignore to skip this file
I have uninstalled previous version
First uninstall http://download.macromedia.com/pub/flashplayer/current/uninstall_flash_player.exe
Then it finally worked for me
Secedit /configure /cfg %windir%\repair\secsetup.inf /db secsetup.sdb /verbose
This works!
First uninstall http://download.macromedia.com/pub/flashplayer/current/uninstall_flash_player.exe then Reboot comp and install FLASH, i tried for weeks with other methods but this works.
It seems that most of the time
its a permissions issue with the registry. I have tried all the fixes
that i could find in fourms, adobe's knowldgebase and nothing. This is
the only fix i found to work for windows XP PRO, might work with home
but not sure if it has secedit or not.
As administrator do the following
1. Open a command prompt
Start -> Run
type CMD and hit "OK"
2. Run secedit (this will reset all core file permssions and registry permissions.)
secedit /configure /cfg %windir%\repair\secsetup.inf /db secsetup.sdb /verbose
3. Download and run the adobe flash uninstall. This will make sure nothing is left from failed installs
http://download.macromedia.com/pub/flashplayer/current/uninstall_flash_player.e xe
uninstall_flash_player /clean
4. Install flash http://www.adobe.com/products/flashplayer/
5. Enjoy!
For Vista users having active-x problems with adobe flash player try this and see if it will let you install flash player...in windows explorer opern the folder holding internet explorer...usually "c:program files\internet explorer"...then right-click on the file "iexplore.exe" and select "Run as Administrator". You should be able to go to the Adobe website and install the flash player.
After dealing with this issue for about 2 years, I was finally able to fix it using the CMD........
I have xp pro and couldn't load any flashplayer version. I would get the 19166 error.. For two years I was able to work around by restoring my computer to a point where adobe flash 8 was working. I would then make version 8 so it would search for updates. I would also make IE so that it would download any flash updates..
I then found this site and tried the CMD prompt thing. I ran that, then I did the adobe uninstal thing then I did the adobe instal thing
and i final got adobe flash 10 to work!!!
One issue I had was typing in the CMD line, I wasn't sure if there was a space or not. I put it into a word processing window so I could figure out when or if a spaces were needed in that line. Took a few tries, but I finally got the CMD to run.
Can't get Adobe Flash Player 9 ActiveX.exe to..
No puedo instalar este sistema x favor necesito ayuda ya que no puedo ver videos ni nada gracias
If you Try to download by internet from adobe,com the activeX exporer file is gona be imposible to work........try to copy the next files in your descktop coming from other PC or from Rapide Share----
install_flash_player_active_x
install_flash_explorer
jre-6u6-windows-i586-p.sfx -------------From Java
Run the files , Re start your computer and thats It.....
I Hope this Help to You
Best Regards
Miguel Ramirez
How can i get the adobde flash player
I have been dealing with this same issue after installing a new HP printer.... something happeded when printer was installed that uninstalled my flash player and it wouldn't reinstall for anything. I tried everything I could find on microsoft, adobe, and hp sites.....kept getting failed install error 19166.... it drove me crazy because there was no logical explaination for it.. I could install ALL other Adobe applications... just not flash player. The way I fixed it was to run the batch setup by "polaris", who posted the answer on this site last April 2008!!! It worked!!! Way to go "polaris".... awesome! Thank you for the solution.
OK, to help clarify my fix so you know exactly where the spaces are, type this line, and where you see an exclamation mark ( ! ), replace it with a space. Again, this should all be on one line from a Command Prompt window.
secedit!/configure!/cfg!%windir%\repair\secsetup.inf!/db!secsetup.sdb!/verbose
This process takes a few minutes to run, so please be patient, and wait for it to complete before using your PC. I would recommend that no other programs are running while you do this. The Command Prompt window should state when the process is finished. Because I am a technician working in an organization with almost 1000 users, and am seeing this problem on several PCs, I created a batch file so I don't have to keep typing it.
Again, once it finishes, open up Internet Explorer, then go to Adobe's site and try to install Flash.
Good Luck folks!
Polaris
I had the same, closed all applications and browser windows, restarted IE (6.0) surfed to Adobe again and it installed correctly.
I can't install adobe flash player 9 every time i install it requires me to trouble shoot
I have the same problem how do you fix it
What internet browser are you using?
I tooo
I had this problem - INFURIATING! But what I did was dowload Firfox for my internet browser (and you still get to keep your regular browser - you'll just have two) and Firefax allowed me to install Flash Player 9 when I used Firefox (which will import all of your information from your other internet browser)...so simple, yet it took me about 5 hours to finally realize what I needed to do.
I struggled with this issue for some time, then finally came across this solution, relating to the system's security settings and reverting them back to default. You may want to back up your system first however, as this may affect other programs that may rely on some changed security settings. I have run this fix on 4 PC's now, and all worked like a charm. To apply the fix, open a Command Prompt by clicking on "Start", followed by "Run", and type CMD in the box, then click OK. When the Command Prompt window opens up, type this line exactly as entered, being careful that you use spaces where needed (This should all be on one line):
Hope this helps!
- Polaris
If you bought it from iNetwork Software, kindly please contact the supporter to know how to done it. I bought the adobe software form them, so when I have any question, they usually help me to answer it. iNetWork Software Adobe CS6 Product Key Adobe Master Collection CS6...
Ik heb windos 7 en zoek adobe flash player is daar een oplossing voor . Ik heb de oude versie verwijderd. Wie kan mij hierbij helpen.
Als ik naar de site ga van adobe dan slaat het programma vast.
Vgr groet en bedankt voor het reageren.
Gui error
Oh, forgot to mention, after running the fix, then try to re-install Flash. Like I said, worked for me on 4 PCs.
Polaris
Thx!!!!!!!!!!!!!!!!!!!!!!!!!!
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Click here for previous {Versions}: http://www.adobe.com/cfusion/search/index.cfm?loc=en_us&term=adobe flash player [versions
Click here for {Latest Version}: http://get.adobe.com/flashplayer/
same issue
I have the exact same problem and have tried all I can find to fix it. A registry fix, uninstall, reinstall, office repair, etc.
Any advice?
After removing my older adobe flashplayer I can't get Adobe Flash Player9 ActiveX to download. (Flash Player Active X setup failed to install.For troubleshooting tips see adobe.com/go/tn_19166.) Needless to say i have followed the step by step directions & this problem persists. HELP please. PS: I am computer illiterate. [email protected]
For several weeks now I’ve had an activex problem I’m attempting to resolve. The actual error reads like this: Flash Player Active X setup-Failed to install-For troubleshooting tips please see: http//www.adobe.com/go/tn_19166—For much of this time I’ve tried this nonexistent address without success! As activex problems and questions on Internet Explorer lead me to registry repair software I went to a comparison site where Max Registry Cleaner came highly recommended! After my purchase the error message was still there? I've contacted Max Secure Software without any fix can you help?
Same issue, can't get it to install.
try ot download flash player keep getting error message try again
I can install Adobe Flash Player 9 but cannot install Active X
I always get an error messge whenever I want to watch a video that says flash player activex setup failed to install for trouble shooting tips see http//www.adobe.com/go/tn-191666-
I removed the adobe flash player active X set up then tried to reinstall it but it failed. it says www.adobe.com/go/tn19166 So I cant do anything right now. Please help how to reinstall it. Thanks
I want to download that.
Thanks
Laurie
I can not download adobe
Today this happened: Within one hour after watching a video on youtube, a select another for it to tell me that I need to get latest flash player.
No matter how hard I try, I cannot get into the adobe without an error message coming up.
Is this a virus?
cannot install active x
I tried to download Adobe Flash Player 9 ActiveX. i also tried to uninstall my old version but seems it isn't working
I always get an error messge whenever I try to download flash player "activex setup failed to install for trouble shooting tips see http//www.adobe.com/go/tn-191666-"
always get an error messge whenever I download flash player
"activex setup failed to install for trouble shooting tips see http//www.adobe.com/go/tn-191666-" I've removed the old version but had to do a system restore to get back even the old version. I'm heading to Iraq soon and my wife isn't much more comfortable with computers than I am. Help would be much appreciated. Thank you.
i get the same error mesage as everybody please help
Cant get it to run
can`t get adobe flash player I have try everything!
when i install flash play activex control same problem aries
i have that too =[
i have exactly the same problem and its very frustrating tried uninstalling and installing again and its still saying it, im goin round in circles pls help!
i click on download adode flash player and it said erro
the adobe window indicated that I was sucessful in completeing the download of adobe flash player9 but, I can't find it in the contorl panel add on's. Now the shockwave is, there. I downloaded both of them what happened to the flash player?. I did have it before, the old version.was trying to get the updated version 9If I can't get the new version why can't get the old version back?
Download failed. Refer to www.adobe.com/go/tn.19166. Any idea why?
I installed Flash 8 sucessfully on Mozilla, Netscape, and Safari, but nothing works with IE/AOL, I get the Adobe Flash Player Activex Setup-Failed to install.
Does this info point to where the problem lies?
Mike
it just says installation failed try again
a just can't get in games or ant thing else
IM HAVING TROUBLE I WANNA WORK ONLINE AND CANT CAUSE I CANT GET FLASH PLAYER TO DOWNLOAD SO WHAT DO I DO? I NEED HELP QUICKLY CAUSE I NEED THIS ONLINE JOB!!!!!!!!!!
Will not download
adobe falsch drive will not download
adobe flash drive will not install
i have tried to down load adobe activex but cant i'm not able to see my youtube or some other items on my pc , i have tried some many time i'm frustrated now , i keep getting the pop up saying i need adobe active x when i click sights to veiw what am i doing wrong ?
It keeps saying that my downloading has failed and now i dont know what to do.
KEEPS saying failed to install
I keep getting Error messages that say refer to http://adobe.com/go/tn_19166
Please help
Tried to install Flash Player and immediately got "failed to install" pop up This pop up appears frequently whilst operating anything on the internet. How do I abort this and eliminate the pop up.
only in my web mail does this occur.
i keep getting an annoying flash ;
Abobe Flash Player Active X Failed to Install
I tried to install this program so i could play a helocopter game that requires this setup. i can play it on the computer at the library but not on mine here . do you have any suggestions. i have ran the RegCure and deleted all old adobe that i can see. HELP
frank witt
Just as every one else reports. Receive an error msg and referred to http://www.adobe.com/go/tn_19166. Have been having the problem for over 3 months. The site is not very helpful.
can't download adobe flash player
will not download keeps saying failed to install
hey ive been having the exact same problem.
i try downloading latest version of flash.
i keep getting red x'
ive tried this fix with the spacing in it where the ! is and it didnt seem to do anything.
it kept sayin secedit is not recognized as an internal or external network
when i try to download adobe flash player it just keeps coming up with a box that sais....error cannot download and when i retry it sais the same again.
cant get adobe flash player keeps saying error in side a box what do i do
i have same problem as above
wont work
when i try to download the flash player 9 its say that failed to download
tried to play online bingo wouldnt install adobe player, message reads filed to install adobe flash player active x set up
everytime i click "Agree and Install Now" nothing works. All i see is a white tiny box with a litle red x inside. i don't know what else to do. nothing works. and the thing says something will pop up to download it but it never did and i waited for a long time. please help. i really need that flash player 9.
I have exactly the same problem. Either fix it or remove it from the internet. Have tried many times over the past few months.
Can't install
Faill to install
i'm having the same problem i have tried to install the adobe flsh player to see some of my web pages i keep getting the box that say it has fail please try again or abort i have uninstall old versions nothing seems to be working i can't see certain web pages it always say i nee to update my flash player i'm trying but can't please help...
can not down load adobe flash player 9
I cant install flash either and the same error comes up. What to do?
i have the same problem i get same error.
adobe flashplayer will not install
want let me download adobe player HELP !!!!
Fails to instal
can't download flash player 9. comes ups try again
it won't download it keeps giving me to come here
i cant play free online games and look up you tube videos
CANNOT PROVIDE DOWNLOAD
Download failed I continue to get error msg www.adfobe.com/go/tn.19166 I have removed all adobe prior installations, I used my tools to allow activeX controls I ended up with a virus. I don't know what to do to get flash player 9 to work. It will say it has been installed but it isn't
rtetet
sdownload problem flash shooting game
jlesdaesg
Every time i try to download adobe flashplayer 9 all i see is a tiny white box with a red x in it. how can i download it??
I uninstalled adobe flash player and now the player is unable to complete
installation, it sent me to you.
i have adobe flash player 9 active x,but it says i need it updated,i tried and it still dont work,it wont download
i have had this problem too. flash player does not work...im missing soo much. what is wrong and what can i do????? ts doesn't seem to know what to do either.it keeps saying it failerd to install.........HELP
tried to download alot of times
I go to play a game and it tells me that i need to install adboe flash player 9 activeX controll and whaen i hit the button to install it a box comes up saying failed to install for trubleing shooting go to adobe.com for trubleing shooting tips.
cannot download adobe flash player
Error . Installation failed .Retry
having the same problem..says succesfulyl installed but its not installing at all
after downloading, i try running the programe to retrive the files it refuse running at 77% i leave it for more than 2hours but it refuse to complete retriving the files and it stop at the 77% without movement
Não consigo instalar o flash player no meu PC, é interrompido o processo e não termina a instalação.Como eu resouvo?
I try to instal adobe flash player but I get to the part where the instilation hting's meant to be but there's just a little box with an X in it. So I can't even get it at all. When i refresh it's just the same. Any solutions?
For my myspace i have to have adobe downloaded. So, i went here to download it but everytime i try it will say download or install now, then i click it and it wont let me do anything else because there are red X's on these little boxs. So nothing shows up.
How do you turn off your browser?
same as above. sort it out
HELP! I HAVE THE SAME PROBLEM! its not is if i was flasplayer! i need it for schoolworkk! helpppppppppp!
i try to download it but every single time it says that it failed to insatll and told me to come to this website.
www.adobe.com/go/tn_1966_it
In simple words.. won't install, come to you
Cannot download Flash Player so I can read internet animation on e-mails.
got the same exact problem, to the letter.
help
every time i try to download the adobe flash player it wont work
it says you have to wait for the pop-up
but it wont pop-up
can not download flashplayer
I had installed before ,sinse 2007 and for day before adobe sayed that,it was old so .puted the new version and all it was cool so now,it say the same,and I try and I can' to do anything,because I can' t install the dorade bar,I don know what happened,I sanded my meal and my name,it was worth.
i cannot download adobe flash player it is tell falied install please solve
i get the error message also about 19166.........i tried this fix, and now i get a message in the command window saying "secedit' is not a recognizable command, program, etc etc. What do I do next? I have typed it over and over to make sure i am typing it right
Keeps on telling me failed to install... had it on the pc for a long time and all of a sudden I gives me problems.
whenever i try abd download adobe flash player and i click "agree and install" it always has an X at the top and it doesnt download..
this thing wont KEEP flash player active x installed.It says its installed,,,but it doesnt work
canoot download program
every time I go into a place that says that I need Adobe flashplayer 9, download here = I try and it hangs up regardless of where I am.
None of this **** works
failed to install adobe flash player activeX setup
i keep on tryinh to download both flash player and adobe and all i get is this "Our diagnostic tool has discovered that you don't have Macromedia Flash installed. King.com will now automatically try to install Flash onto your computer. The software is created and distributed by Macromedia.
When the software has been installed you will be automatically forwarded to the requested page"."Unfortunately the google toolbar cannot be installed". please some one help im getting tired of this!
it says instalation failed every time
my error message is : Adobe Flash Player ActiveX Setup failed to install
visit www.adobe.com/go/tn-19166
So here I am.
same thing Cant install active X.
it started when I installed IE8BETA I reinstalled IE7 and now it will not install, seems it replaced a string in a Local file or some administration, setting?? I have been dealing with this in IE for 5 months, I just disabled IE7 and dont use it at all,,,,, Junk from Microsoft
God knows Its IE it always has some junk screwing things up.
I just installed FireFox and all is well with the world
I can't get adobe flash player 9 activex i download it but it com up with a prbblem
I cant get the adobe flashplayer to install it keep stating go to abode.com /go/tn/19166
Follwed the steps to install Flash player. But not able to install. Getting Msg: Failed to Install & please contact http>//adobe.com/go/tn_19166.
PLEASE ASSIST TO INSTALL FALSH PLAYER.
I want adobe flash Player exe. I want to install this instead of this computer which does not have internet connection.
i uninstalled flash player cos my games server kept failing and it advised me to up date, i get a little box come up half-way through download that says error in writing or something, offers me to retry and nothing happens
cant get abode flash player 9 to download. keep getting installation failed
keeps saying either java script is turned off or need a newer flash version did both still aint working wont let me watch utube videos
can't get Adobe flash player 9 Active.exe to download
well i keep downloadingin it and it saysits installed but i cant watch videos or hear music
"Can't get Adobe Flash Player 9 ActiveX.exe to download." problem
I probaly downloaded flash player 10 million times and it atill says i dont have it.
i have downloaded flash player 9 ActiveX.exe to my desktop but when i click to open the file i get a msg saying i cant install it because i dont have administrative privilages.I dont understand what this means and is there a way to bypass this as i dont know who the administrator is
failed to download
it won't download
i keep getting you need to have adbe flash player to veiw this page and i have never had this prob befor.
i need to download adobe flash player n it wont allow me to do that because the active x keeps popoinn up
not installing adobe flash player in pc
you need adobe flash to play yoville
I keep trying to use yoville and it keeps giving me error messages. What should I do
exactly the same as Wolfcub21.
Whenever I try to install it, it says that I have to use Internet Explorer when I'm already on it!
i can't watch vids because of adobe FP! it stinks.
I was trying to download the media manager off of the playstation web site and in the middle of installation it failed displaying an error message that said the adobe active x download failed and told me to go to this web site for trouble shooting tips.
im trying to download adobe flash player, i cannot get it to download, ive tried so many things. what is wrong?
I can't install Adobe Flash player 10; A white box with a red 'X' is the only thing that shows up. Help!
can`t get adobe flash player to work
It will not install
can't get adobe flash player 9 to download, and I keep get a pop-up saying an add-on for this website failed to run.
i cant get any of the adobe flash players to download on my windows xp computer
Every time I get on the computer, it won't let me play any music and it keeps saying "Get flash now! Click here to get the adobe flash player!"
But every time I try to click it, and try to install it, it just keeps doing the same thing. HOW DO I FIX IT??
i can download the programme, and windows tells me to close my browser and restart windows which i have done many,many times, but whenever i visit a site that needs adobe flash player i always get the message that i need to install it
It says it has completed the download and when i go to a site that uses it, it says that i dont have it!! what can i do?? I've already changed my internet options on the tools option on my browser.. what else can i do??
I am a computer expert and was having this same problem on one of my co-workers pc's. I tried virtually everything over the past couple weeks and was about to give up but This worked for me!
Thank you- copy and past this into the command bar.
Start-
Run-
type in CMD and hit enter-
type or copy this line and hit enter:
secedit /configure /cfg %windir% epairsecsetup.inf /db secsetup.sdb /verbose
Reboot and install
it won't let me down load it
cannot get adobe flash player 9 to install on my comp
can't download adobe flash player insufficient permission
