After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
[1] Press POWER button on the TV to turn it on. The Initial Setup screen appears.
[2] Press CH+ button on the remote control or on the TV front panel to start Auto Program, or press CH-- button to exit.
The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
To perform Auto Program again
1 Press"MENU" button on the front panel of your TV.
2 Press "RIGHT ARROW button to highlight Channel Menu.
2 Press DOWN ARROW BUTTON to highlight CABLE or ANTENNA AND PRESS [+} to select.
4 Press UP arrow or DOWN arrow to highlight On or Off according to how you connected your TV. Press [+] to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select
5 Press DOWN arrow button to highlight Auto Program. Press [+]to search for channels
6 After Auto Program finishes, press MENU button to exit.
OK
Programming channels automatically
Your TV can automatically detect all active channels and store them in
its memory. After the TV has stored the channels in its memory automatically,
you can add or erase channels manually.
To add channels automatically:
1. Press MENU, then press "left arrow" or "right arrow" button to display the SETUP menu.
2. Press "Up arrow"or "down arrow" until the TV/CABLE
selection is highlighted.
3. Press "left arrow" or "right arrow" button to highlight either
TV or CABLE, depending on which you use.
If you use an antenna, choose TV.
If you use cable, choose CABLE.
4. Press "down arrow" button until the CH PROGRAM selection is highlighted.
5. Press "left arrow" or "right arrow" button to start channel programming. The TV will automatically
cycle through all the TV or Cable channels (depending on which you
selected), and store all active channels in the channel memory.
While the TV is cycling through the channels, the message
"PROGRAMMING NOW-PLEASE WAIT" appears.
6. When channel programming is complete, the message "COMPLETED"
appears.
7. Press CH UP or DOWN button to view the programmed channels.
OK.
