Epic View 550 Treadmill Logo
A
Anonymous Posted on Jun 17, 2014
What would cause a number 3 to appear on sportcraft ts400 after just a few seconds
Sportcraft tx 2.5 shows code 3 and stops after a few seconds of running time.
If you wish to get some details treadmill repair and error code ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
SPORT TRac treadmill shuts off after a few seconds
1) LUBE THE DECK BELT, this produce enough friction for shutdown the machine.
2) LUBE the rollers bearing very well.
3) Test the input voltage motor, if there are VOLTAGE, the motor need repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
See the block diagram. God bless you
17helpful
2answers
Treadmill stops after 7 seconds
you have a broken spinner. Take hte motor cover off and look on the opposite side of the motor. there will be a partof the spinner wheel there. I have yet to find a way to short cirut the connectors nor a replacement wheel.
5helpful
Turned on, runs a few seconds, shuts off with a #3 on display
Contact the manufacturer. You need the optical disc. It is the speed sensor. Eric For Treadmill replacement parts, please contact our Consumer Affairs Dept. at (800) 526 - 0244
Sportcraft TX 2.5 treadmill - error code 3 - stops after a few seconds of operation. ??? Thanks for any advice
Sorry I dont have the solution but I have the same problem.
Read somewhere that Sportcraft control boards had
a design flaw.
Talkwitch 240VS and TS400 phone
To setup the phone to automatically insert your external dial group (usually '0') before numbers, so you can save them in your phone book, and make calls from your missed / received call logs, you should check the TS400 manual.
For the TS350i you do this 1) press transfer/menu button 2) Press 4 - Call preferences menu 3) Press 8 - Access Code Prefix 4) Enter the number you use for outgoing calls (usually 0) 5) Press OK
Top Epic Exercise & Fitness Experts
ADMIN Andrew
ADMIN Andrew
Sportsmith LLC
Sportsmith LLC
Don A
Don A
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
