SOURCE: Hoover washing machine - door won't open and drum
1. please provide the model number for the washer
2. this is a timer error code and it seems that it locked the door during the spin cycle.
There may be a malfunction sensor or you will need to unplug the washer to reset the washer to complete the cycle.
Something electronic has caused the washer to shut down to protect the electronic circuit. You may have a defective timer.
Testimonial: "Thanks for your help, it's working fine now :-) "
SOURCE: Hoover WMH168D error code E08
I posted this elsewhere by mistake, I have a Hoover Optima which had an E08 fault, the forums suggested a Tachometer issue. I fixed the fault it was just the motor brushes. i made a video including testing the tacho and changing the brushes that cost me a tenner. easy fix hi I had this fault google said it was tachometer fault. the e08 fault on my hoover optima was not the tachometer, i checked it, but the fix was very easy, the motor brushes were worn out and i changed them for 10 quid, I made a video of it its on you tube http://www.youtube.com/watch?v=xYn-f78GB4U if its any use.
