SOURCE: I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
SOURCE: Kyocera fs-1118 When I want to use scanner
are you able to take print ........... and have you installed the paper cut software for scan the document ..... please check while you connecting printer to your pc its detecting or what ...... please check above thing .... please post your comment if you facing same problem ...............
Testimonial: "Yes i can print. But only for scan i got message cannot...I search site kyocera and install printer driver and TWAIN driver.USB cable replaced"
SOURCE: telecharger driver kyocera fs-1118
Go to the manufactures website using this link, http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=20418&rid=22655, and the diver for the FS-1118MFP will be included in the download.
I hope this is helpful,
Shawn
SOURCE: KYOCERA ECOSYS FS-1118 ERROR-C-6400
Error code relates to the fuser unit.Suggest that it is replaced.
