The TV screen went blank and the power light on the front TV blinks on and off. What is causing this problem and how can I fix it?
SOURCE: blue light in the front blinking no picutre no sound
This is the shutdown code for the lamp ballast. I would have a technician verify ballast is bad and replace. This can be a tricky repair for a novice because installation of the ballast requires that you remove the light engine. Hope this helps.
SOURCE: how do i reset my jvc tv
Either a bad lamp or bad reciver board.If audio amp ic on reciver board shorts ,it will kill part of supply and lamp ballast will not turn on and fire lamp.
SOURCE: JVC TV Front panel power button blinking
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also
ensure that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem with no receiver box
or dvd connected.
If that does not work, and you keep having a flashing
led on front of the TV, and tv turning off by itself after a while,
that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The
internal circuits are jammed because of electrostatic
charges accumulating on capacitors, or because of a wrong voltage read
by the main chip on your monitor controller board. this started the
protection circuit.
2 The protection circuit detected a wrong
voltage or abroken contact, identified an internal fault and kicked in
, startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults
that can occur are a blown capacitor on power board, a
convergence IC has blown, or a fault on Digital board.
Check also
the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you
can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
SOURCE: Light blinking on tv
Also
or dvd connected.
1The
protection circuit.
Common faults
Check also
