Kodak EasyShare C613 Digital Camera Logo
A
Anonymous Posted on Jun 17, 2014
How can i get pics off internal memoery - Kodak EasyShare C613 Digital Camera
1helpful
How to download the internal memory of my Panasonic Lumix DMC T27 to the memory card
Go to previous view pics in internal memory, select the pic and then "move"at SD Card (work in some models).
Other possibilitie, take off the SD card and connected the camera at pc, open explorer software and copy/paste the pics from camera at one folder in the pc. Verify that the pics are saved and secure, so, delete the files in the internal memory. Turn off and unplugged the camera.
Then, take on SD card inside camera and reverse procedure, copy/paste from pc to SD card (like a external device).
Hope helps.
May 25, 2011 • Cameras
I need to transfer internal memory photos onto memory card
First need to take off the SD card; default settign make the SD card as main stored when this is inside the camera.
Take off the SD card and send the internal memory pics at pc folder (use USB connection); insure that the pics are in this pc folder, them delete the files in "internal memory".
Take on the SD card inside tha camera and send pics from pc folder at camera, confirm that the pics are there.
Hope helps.
Says internal memory is full. how do I clear it
You have to delete the pictures in the memory using the camera's function to do this. If you have a memory card in the camera, you might not be able to see the pics in the internal memory, so take it out first, then review the pics in the camera and delete as many as you can (not the ones you want to keep, obviously). When you put the memory card back in, the camera should save pics to that instead of internal memory, but if the internal memory is completely full, it can't work properly. It needs some elbow room.
2helpful
Kodak easy share wont delete or scan to the left to view pics
In order to solve the problem you need to transfer pictures from the internal memory to the SD card and thereafter you will be able to delete the pics in the internal memory.
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  1. On the camera, press Review and then Menu.
  2. Select Image Storage.
  3. Change to Internal Memory.
  4. In the menu listing, scroll down to Copy, and select OK.
  5. Select a single picture, or select All.
  6. When you have finished copying pictures, reset the Image Storage location to your original setting.
1helpful
Internal pics
if it's just seen on the XD card, then those pics were not saved in the internal/built in memory of the camera. Anyway, if you want to delete pics in the XD memory, just insert it in the card reader of your computer then just delete the pictures or format the memory card.
cheers!
Jul 11, 2009 • Cameras
8helpful
Move pics from internal memory onto a Sim card
Press "Menu".
In the menu go to the symbol (wrench and camera).
Go to the "image storage" and choose "Internal".
Leave the menu. Press "preview". You'll see only pic's from the internal memory.
Press "Menu" ... "Copy" and choose all.
After that go back to "image storage" and choose "Auto"
2answers
Dont know how to get pics out internal memory
Actually, you can do it without the cable.
You need to have the card inside your camera with at least ONE picture. Hit play. Press menu. Scroll down until you see COPY and then choose "Internal to SD Card" Hit All Frames. Hit OK. Done.
Cheers,
V+
Transfer pics from internal memory to Sims card
when reviewing pictures on the internal memory push the menu button. There is an option to copy the pictures to the memory card.
Digital camara
Yes. Check the Manual for your camera or scroll the menus.
Internal memory full!
    The internal memory for taking number of snpas depends on that on which Mega Pixal you are using. Hope that intentally or un-intentally you had change Mega Pixal from low to high, that's why the number of pics in internal memory reduces. Just keep your camera snaps mode (Where you take pics) then press junk or dustbin button and you can change the Mega Pixal quality as you want. Higher MP gain more memory and give less number of pics but with high resolution and lower MP gives large numer of pics with low resolution.
Hope you will under stand my sayings.
Thanks for using FIXYA!
Take care
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
