The pattern of the blinking can tell you a lot. if you can get the pattern and then reference the following site it can tell you the cause and some steps to remedy the situation.
Support Article This is a Dell Article that explains the various Blink Codes it covers the entire OptiPlex line, including all the changes that were made through the years.
Another option would be to print out the relevant portion of that page and keep it for future reference as well.
SOURCE: Dell OptiPlex GX520 PC Desktop Problem
An Amber blinking power button indicates a low or missing voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
SOURCE: Dell (ie optiplex 330) would not boot with the orange light on
Do you have a lot of accessories plugged in? They may have overloaded the power supply and if this is the case you will need to buy new power supplies. If this is not the problem, check to make sure that the computers have plenty of ventilation in the back. If they don't, they may have overheated and melted quite a few different components.
SOURCE: my dell optiplex 330 can not switch on, whan I put
If you are getting an amber light flashing, your power supply is faulty.
If it is a solid amber light, you motherboard is faulty or one of the componants are faulty.
I would suggest giving Dell a call. They would beable to pin point the problem and give you a quote. Some of their componants are non standard and can only be purchased from them.
You could try reseating all your componants on the last resort but it is unlikly to help.
SOURCE: Dell dimension 5150 blinking amber lights
I have similar problem these days. After normal shutting down the PC, it can not be powered up again, the amber light blinks. A temp solution for my case is by doing these steps:
1. leave all monitor, network, keyboard and mouse etc. connected
2. disconnect the power, wait until green light and amber light dim.
3. pop up the CMOS battery, then put back in (better to check its remaining voltage, if not good, change a new one)
4. power amber light flash shorter and lighter
5. disconnect any USB connections like keyboard and mouse,
6. immediately connect keyboard and mouse back into USB ports
7. my pc powers up at this point, all green lights shining. Except it displays CMOS setup warnings, give me options to click either F1 or F2
8. I click F1, it goes into normal login XP
The only problem is I could not shutdown PC again, if I do, then I have to repeat 1-8. I have to use "Standby" instead, which I usually do.
SOURCE: Dell optiplex 330 flashing orange on the power botton
Try to clean the RAM and place it again in the motherboard.
