Olympus Stylus 850SW Digital Camera
SOURCE: Olympus Stylus 790SW "Blue screen"
appears to be repair issue and need to send to a repair center
SOURCE: I have new olympus 850SW
To access the panorama mode in the camera you need to be in P mode.
To set the P mode you need to press the Ok button right arrow to P for Program Auto and press Ok. Then as long as you are using an Olympus xD card you should be able to go to menu and highlight the Panorama option.
SOURCE: Pixel problem, all pictures taken have poor pixel resolution
It sounds like you set the file settings to a small file size - perhaps in order to get more photos on a single memory card. You need to change the setting to the largest file size possible, at the highest quality. The steps for this will be in your manual. If you need detailed instructions and don't have your manual, let me know and I'll lookup your manual online.
SOURCE: Olympus Stylus 410 Digital is taking grey/black pictures
The problem you are describing is a problem with one of the chips in the camera that controls image processing. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $83 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
SOURCE: picture error message on olympus 1200
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the Picture error message and the card can be used again. The picture error message indicates that this image is now corrupted and unable to be viewed through the camera.
