Resolve Toshiba Error Code f3 f200 0002 normally happens temporarily and a system reset then disappears afterwards. You want to go through a number of possible reasons to find the exact reason for this.
Effective Methods to Overcome Toshiba Error Code f3 f200 0002:
Whenever this error appears, you need to go through a number of possible reasons to determine the actual cause. This blog will help you to fix this Toshiba Error Code f3 f200 0002 with the help of step by step solutions. You can also connect with Toshiba Customer Care Service to get to the roots of the error.
Perform a system recovery on the computer to repair this Toshiba Laptop error as easily possible.
Recover your Hard Drive using the following steps:
Shut your computer down by clicking on the Start and thus "Shut Down" button.
Depress your system's power switch while holding the 0 key pressed.
The Toshiba HDD Recovery Utility screen will appear as soon as the computer turns on.
When you restore a hard drive to its factory default state, all partition on the hard drive and the data stored within it gets deleted. Make sure to back the important files before performing the restore process.
Next, you need to press 1 to restore your hard disk to its original factory default state.
An alert message will appear saying "all data will be overwritten and lost during the restore process". Back up the files before proceeding.
After that click on Yes option to start the restoration process.
You will be notified with a message saying the HDD has been restored.
Press any key to restart your Toshiba Laptop.
If the 0 key does not start the recovery process, it means that your system does not have an inbuilt recovery option. On such case, use the Toshiba recovery disk that comes with your Toshiba laptop.
E000 0000 Fixing temperature abnormal rise E001 0000 Fixing unit temperature rise detection (by main thermistor) 0001 Fixing unit temperature rise detection (by sub thermistor) E002 0000 Fixing unit temperature insufficient rise E003 0000 Low fixing temperature detection after standby (by main thermistor) 0001 Low fixing temperature detection after standby (by sub thermistor) E007 0000 Fixing film rotation error E010 0000 Main motor rotation error E019 0001 Waste toner full detection 0002 Waster toner full detection sensor failure E052 0000 Duplex unit connection error E100 0000 BD cycle out of range E197 0000 Erroneous communication with printer engine E500 0001 Finisher communication error E520 0000 Offset error E531 0000 Stapling error E540 0001 Paper surface not detected (standard tray) 0002 Not moved within the specified time (standard tray) 0003 Sensor not reached within 3 seconds (standard tray) 0005 Encoder clock failure (standard tray) E542 0001 Paper surface not detected (optional tray) 0002 Not moved within the specified time (optional tray) 0003 Sensor not reached within 3 seconds (optional tray) 0005 Encoder clock failure (optional tray) E575 0000 Stack delivery error E584 0000 Shutter failure E716 0000 Erroneous communication with optional cassette E719 0000 Erroneous communication with card reader (serial communication) 0002 Erroneous communication with coin vender (serial communication) E733 0000 Erroneous communication between controller and printer E736 0000 CCU communication error E739 0000 Erroneous communication between controller and network board E744 0001 Language file/boot ROM/USB memory error 0002 0003 0004 E805 0000 Fan failure E808 0000 Fixing drive circuit failure
This prompt comes when the printing documents are too complex. At this time press continue it may start the printing and to remove the problem for future follow the steps as bellow.
Click Start-Settings-Printers .
Highlight the HP LaserJet 4 icon.
Choose File and verify there is a check by Set as Default-Choose Properties-select Device Options and verify the memory setting shown here is the same as what the printer has installed.
Select the page protection option and then choose OK .
Close out of the Printers folder and try printing again.
E000 0000 Fixing temperature abnormal rise E001 0000 Fixing unit temperature rise detection (by main thermistor) 0001 Fixing unit temperature rise detection (by sub thermistor) E002 0000 Fixing unit temperature insufficient rise E003 0000 Low fixing temperature detection after standby (by main thermistor) 0001 Low fixing temperature detection after standby (by sub thermistor) E007 0000 Fixing film rotation error E010 0000 Main motor rotation error E019 0001 Waste toner full detection 0002 Waster toner full detection sensor failure E052 0000 Duplex unit connection error E100 0000 BD cycle out of range E196 0001 Error on writing and readout ROM of image processor PCB (main ROM). 0002 Error on writing and readout ROM of image processor PCB (option ROM). E197 0000 Erroneous communication with printer engine E261 0000 Zero-cross signal error E500 0001 Finisher communication error E520 0000 Offset error E531 0000 Stapling error E540 0001 Paper surface not detected (standard tray) 0002 Not moved within the specified time (standard tray) 0003 Sensor not reached within 3 seconds (standard tray) 0005 Encoder clock failure (standard tray) E542 0001 Paper surface not detected (optional tray) 0002 Not moved within the specified time (optional tray) 0003 Sensor not reached within 3 seconds (optional tray) 0005 Encoder clock failure (optional tray) E575 0000 Stack delivery error E584 0000 Shutter failure E716 0000 Erroneous communication with optional cassette E719 0000 Erroneous communication with card reader (serial communication) 0002 Erroneous communication with coin vender (serial communication) E730 0000 Inside error of the image processor PCB (PDL system error) E733 0000 Erroneous communication between controller and printer E736 0000 CCU communication error E739 0000 Erroneous communication between controller and network board E744 0001 Language file/boot ROM/USB memory error 0002 0003 0004 E805 0000 Fan failure E808 0000 Fixing drive circuit failure
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i
Код ошибки
Субкод
Описание
E000
0000
E001
0000
0001
E002
0000
E003
0000
0001
E007
0000
E010
0000
E019
0001
0002
E052
0000
E100
0000
E197
0000
E500
0001
E520
0000
Offset error
E531
0000
Stapling error
E540
0001
0002
0003
0005
E542
0001
0002
0003
0005
E575
0000
E584
0000
Shutter failure
E716
0000
E719
0000
0002
E733
0000
E736
0000
E739
0000
E744
0001
0002
0003
0004
E805
0000
Fan failure
E808
0000
E007 Fixing film sensor failure The fixing film sensor is faulty. - Check the connector of the fixing film sensor. - Replace the fixing film sensor. - Replace the DC controller PCB.
you need to call a canon technician to sort it out
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i Код ошибки Субкод Описание E000 0000 Fixing temperature abnormal rise E001 0000 Fixing unit temperature rise detection (by main thermistor) 0001 Fixing unit temperature rise detection (by sub thermistor) E002 0000 Fixing unit temperature insufficient rise E003 0000 Low fixing temperature detection after standby (by main thermistor) 0001 Low fixing temperature detection after standby (by sub thermistor) E007 0000 Fixing film rotation error E010 0000 Main motor rotation error E019 0001 Waste toner full detection 0002 Waster toner full detection sensor failure E052 0000 Duplex unit connection error E100 0000 BD cycle out of range E197 0000 Erroneous communication with printer engine E500 0001 Finisher communication error E520 0000 Offset error E531 0000 Stapling error E540 0001 Paper surface not detected (standard tray) 0002 Not moved within the specified time (standard tray) 0003 Sensor not reached within 3 seconds (standard tray) 0005 Encoder clock failure (standard tray) E542 0001 Paper surface not detected (optional tray) 0002 Not moved within the specified time (optional tray) 0003 Sensor not reached within 3 seconds (optional tray) 0005 Encoder clock failure (optional tray) E575 0000 Stack delivery error E584 0000 Shutter failure E716 0000 Erroneous communication with optional cassette E719 0000 Erroneous communication with card reader (serial communication) 0002 Erroneous communication with coin vender (serial communication) E733 0000 Erroneous communication between controller and printer E736 0000 CCU communication error E739 0000 Erroneous communication between controller and network board E744 0001 Language file/boot ROM/USB memory error 0002 0003 0004 E805 0000 Fan failure E808 0000 Fixing drive circuit failure
