SOURCE: i want webcam driver for dell vostro 1014
You can use the vista driver found in the support site of dell
SOURCE: in order to configure TCP/IP,you must install and
Not much to go on with your question. Windows 7 does not see your network adapter(s). Did you just upgrade? If so, you might need to go back to Dell website and download the Win7 drivers for you laptop. On that laptop you should see 3 network interfaces for WiFi, Ethernet, and the modem, and possibly a 4th for bluetooth. Dell is pretty good with downloads - just type in your service code at their support site, and they will only show you what you might need for your computer.
SOURCE: i have windows 7 in
good day sir. this is quite a complicated problem. and i found a site where they discuss this problem and gave several solutions that might help you. here it is:
http://support.microsoft.com/kb/941997
hope this helps. goodluck and please rate my answer. thanks
SOURCE: webcam driver needed for dell
Go to the site below. Double check the model and then fill in your operating system type and other info. This will take you to the page that has all the drivers for your laptop. You should find the webcam driver there.
http://support.dell.com/support/downloads/driverslist.aspx?c=ca&cs=cadhs1&l=en&s=dhs&ServiceTag=&SystemID=VOS_N_3500&os=W732&osl=en&catid=&impid=
Make sure the link includes the = (sign) at the end of the line that didn't copy correctly here.
SOURCE: my dell vostro A860 cannot
Wireless Internet has become increasingly popular as a means of connecting to the Internet. Wireless networking allows for users to connect to the Internet without having to physically plug anything into the computer. If you are not able to connect to any wireless Internet connections, it is important to take a few simple troubleshooting steps on your own to understand the cause of the issue and resolve it.
1.Try connecting to multiple wireless networks. The first step in diagnosing a lack of wireless connectivity is to try more than one wireless network. This will give you an idea of whether the problem is with your laptop or just with the single wireless network to which you are trying to connect. Take your Dell D600 to one or more free public wifi hotspots and try connecting wirelessly there. If you are able to connect to other wireless networks, the issue is more likely with the single wireless network you first tried to connect to; contact the person that manages that network to resolve the connectivity issue.
2.Verify that your wireless card is enabled. If you are not able to connect to any wireless network, it is important to make sure that your laptop's wireless components are enabled. All modern laptops come with what is called a radio button, a way to enable or disable your laptop's wireless card with the touch of a button. The Dell D600 has the radio button assigned to the F2 key. To make sure it is enabled, hold down the Fn key on the bottom row of the keyboard and press the F2 key. A pop-up window on the laptop should now indicate whether your wireless card is enabled or disabled; make sure it is set to enabled.
3.Verify your wireless card drivers. Navigate to your computer's Device Manager by clicking "Start," right clicking on "My Computer," choosing "Properties," clicking the "Hardware" tab and clicking "Device Manager." Locate "Network Adapters" from the list of hardware devices and click the "+" icon next to it to expand its contents. Among the contents, locate anything with "Wireless adapter" in the name and check to see if it shows a "?" "X" or "!" over the name. If it does, or if there is no wireless adapter showing under network adapters, your wireless card may need to be replaced or may need a software-driver update. Contact the manufacturer of your computer or take the laptop to a computer-repair store for further assistance.
I hope you find it very helpful. Best regards.
