SOURCE: Zebra 4M Plus printer keeps printing same label
Hi there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: Label double print
It's possible that the printer did not get a good calibration on the size of the label. There's an optic sensor looking for the gaps in the labels. A test would be to turn the printer off and back on again. When it is ready, just press the feed key. If one label advances then the printer had a good read on the label size. The idea is to see if the printer works ok by itself first.
Now print a label - if you get two labels then you have to look at the software / printer driver as the cause. The printer will only do what it's told to do.
Hope that helps !
