You say that you replaced the door switch, but you need to check that the spring of the latch hook inside the door is working properly, otherwise it does not hook properly and will cause these problems.
bleach? do u mean detergent? normally machines run pump/then start to fill.water will pass through drawer then they heat /wash/drain/spin then refil for rinse conditioner/spin rinse drain fast spin end pretty much
I would be leaning more in the direction of the door lock mechanism rather than the hall sensor as someone else posted. The hall sensor gives a very specific error code when it goes bad. Put the unit into a spin only cycle and verify that the door is locking. To do this power up the machine and only press spin speed and the start. It is also possible that it is a problem with any one of the three control boards that are on the unit but again, these normally present with very specific error codes. If the door is not locking, or even if it is but the switch isn't sending the signal back to the main control saying that it is locked then all it would do is drain and then spin 1/3 turns either way inside the tub until time runs out.
OE means your machine has failed to drain within 10 minutes. There are a few posibilities. Your drain hose could be kinked or clogged causing the machine not to drain. Try using a shop vac to remove the water from the end of the drain hose. If a shop vac won't **** out the water either, you have a clog somewhere ing the drain hose, of the hose from the tub to the pump. If it will drain the water you need a new pump. If there is no water in the machine then the problem is either the pressure switch, the hose going to the pressure switch, of the control board. The pressure switch is on the back by the control board. You will see a black rubber hose going attached to it. Remove it and see if you can blow through it. If you cant it is clogged somewhere. If it is not clogged then the most likely cause is your pressure switch and next the control board.
same problem. LG stated I am using too much soap. Cant be because it still does it with no soap. Also have issues with spinning on bed comforter and also drum will not drain. I can wring out a 16oz of water from a cotton shirt sitting in the bottom of drum when completed. Floor is flooded and I am **********. Bought in April 2010 and have had 4 techs out to look at it, but there is no problem. Biggest waste of 600 I ever spent.
