Question about Shopnbc Zeki 10" 8GB Android 4.0 Ice Cream Sandwich Multi-Touch Screen Tablet
What to do if ANDROID IS SHOWING ON SCREEN
When I turned power button on Zeki would appear for a second. then screen would display on The Word ANDROID locked on screen
  • The Scrivener Jun 23, 2014
    Hi Anonymous, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Do you have any security set up on the tab? Does it require a password on startup. If you use a 3rd party security app. on startup what is it?
    Kev.'
    New Friend:
  • 3 Answers
Try to hold your off button for several minutes and see if it turns off, then turn Zeki on again...that may clear it from screen.
Posted on Jun 20, 2014
6ya staff
SOURCE:
Where is the reset button on a zeki windows tablet located at
Hi Brenda, The link below is a youtube video showing you how to fix your tablet, Also there's video's down the right side you can check out as well....CHEERS..
https://www.youtube.com/watch?v=0PAB6khykWE
How To fix any Android Phone Tablet that won turn on
Apr 24, 2016 | Tablets & eReaders
Get rid of dead robot
try clearing your cache partition, you can get to the android recovery with your buttons.
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Jan 21, 2015 | Tablets & eReaders
Help to reboot my tablet
Hi, you need to perform a factory reset, follow these instructions:
Dec 31, 2014 | Tablets & eReaders
I turn on zeki tablet and it possible up that everything stopped working and it won't leave the camera. How do I fix this
You can reset the Zeki by Powering off. Then at the same time press the volume up button and the power on button, hold them until the Android splash screen pops up.
Nov 12, 2014 | Tablets & eReaders
I've had several issues but the one now is that all my tablet will do is show a pic of an android laying down with a red triangle on it bearing an exclamation mark. At the bottom of the screen it says NO...
Oct 29, 2014 | Tablets & eReaders
My 7" zeki tblet model TBDG773B comes on and shows android and nothing else will.
You can try a factory restore, but if that doesn't work you will need to buy a new tablet. These cheap tablets are throw-aways unfortunately. Note that a factory restore will erase any files you have on the device.
Factory Restore on Android devices:
- Turn off the device
- Hold Volume Down and also press the Power button until a menu comes up
- Use the Volume Up and Down buttons to select Factory Reset (or Restore)
- Press Power to select
Oct 28, 2014 | Shopnbc Zeki 7" Multi-TouchTablet
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
Oct 27, 2014 | Tablets & eReaders
I bought the tablet off of face book yard sale and
hi there.
this is all i could find out from the internet so not sure if it will work for you.
I think it,s time for a factory reset , you will lost all you data !!!!!
or try this link out.
android man on his back with red triangle on his chest Google Search
Dec 15, 2017 | Tablets & eReaders
How do i get it off the android screen so it will show the lock screen?
Sounds like its borked.
Have you pressed the reset button on the back - pinhole - press it with a pin its a long shot.
The real fix is to go into recovery mode using the power button volume up combo. Then select the restore tablet option.
If none of that works you will have to sideload or reinstall using an sdcard a replacement OS - Try cyanogenmod - your tablet will have to be rooted and have the cm bootloader installed however - tablets are not easy things to repair when the software goes belly up.
May 12, 2014 | Shopnbc Zeki 10.1" LCD Android 4.1 8GB...
I put a password on my android tablet and now i dont remember the password
Make sure you backup your files by connecting it to a PC (if you have access to one) via USB cable,you will have to do a hard reset, otherwise there is no other way to get past the lockscreen (unless you have a recovery option with your email address)
Below is the process to tell you how you can hard reset your Samsung tablet (should work with any tablet):
  • Ensure that the Samsung tablet is powered off.
  • Press the Power and the Volume Up button together till the device displays the start-up logo.
  • Once the logo is displayed, release the buttons and wait till the device enters the Android system recovery mode.
  • On the displayed screen, use Volume Down button to go to the wipe data/factory reset option (Volume Up and Volume Down buttons are used to highlight the displayed options on the Android system recovery screen).
  • Once the option is highlighted, press the Power button to select the option. (Pressing the Powerbutton in Android system recovery mode selects the highlighted option.)
  • On the next screen, press the Volume Down button multiple times till the Yes -- delete all user data option is highlighted.
  • Press the Power button to hard reset the Samsung tablet device while clearing the dalvik cache along with the process.
  • Once your device is hard reset and rebooted successfully, you will see that the unlock pattern obstruction is also gone, and you can now set a new unlock pattern on your Samsung tablet.
Oct 21, 2013 | Tablets & eReaders
Shopnbc Zeki 10" 8GB Android 4.0 Ice Cream Sandwich Multi-Touch Screen Tablet Logo
260 people viewed this question
Top Shopnbc Tablets & eReaders Experts
The Scrivener
 Mike M
Mike M
Giulio Moro
Are you a Shopnbc Tablet and eReader Expert? Answer questions, earn points and help others
