2011 Yamaha FZ16 Logo
A
Anonymous Posted on Jun 20, 2014
SPEEDOMETER NOT OPERATE
Where is the speed sensor located on a 2006 Lincoln mark LT pickup
The instrument cluster receives the vehicle speed sensor (VSS) signal which originates in the ABS module and is transmitted to the PCM over the communication network. The PCM monitors the VSS input and sends it to the instrument cluster over the communication network. With the VSS input, the instrument cluster provides the speedometer with a corresponding pointer movement.
  • The speedometer/odometer is inoperative
  • Powertrain control module (PCM)
  • Instrument cluster
  • Go To Pinpoint Test F .
Pinpoint Test F: The Speedometer/Odometer Is Inoperative
Normal Operation Vehicle speed information is sent to the powertrain control module (PCM) from the anti-lock brake system (ABS) module. The instrument cluster receives the vehicle speed data from the PCM over the communication network.
    Possible Causes
  • PCM
  • instrument cluster
PINPOINT TEST F: THE SPEEDOMETER/ODOMETER IS INOPERATIVE Your best bet ,have the vehicle hooked to a professional scan tool an checked for DTC'S - diagnostic trouble code's , before you replace parts that are not needed.
Test Step Result / Action to Take F1 RETRIEVE THE RECORDED DIAGNOSTIC TROUBLE CODES (DTCs) FROM BOTH THE CONTINUOUS AND ON-DEMAND PCM SELF-TESTS
  • Check for the recorded PCM DTCs from the continuous and on-demand self-tests.
  • Are any PCM DTCs recorded?
Yes
REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual to continue diagnosis of the DTCs.
No
For an inoperative speedometer, GO to F2 .
For an inoperative odometer, GO to F3 . F2 CARRY OUT THE INSTRUMENT CLUSTER SPEEDOMETER GAUGE ACTIVE COMMAND USING THE DIAGNOSTIC TOOL
  • Key in ON position.
  • Enter the following diagnostic mode on the diagnostic tool: Instrument Cluster Active Command.
  • Select the instrument cluster speedometer gauge active command. Trigger the active command on. Observe the speedometer gauge. The speedometer gauge should start 16 km/h (10 mph) and move to 194 km/h (120 mph).
  • Is the speedometer gauge within specifications?
Yes
GO to F4 .
No
GO to F5 . F3 MONITOR THE INTEGRATED CIRCUIT DISPLAYS
  • Monitor the compass, air temperature and message center functions of the integrated circuit display.
  • Do the compass, air temperature, or message center displays operate correctly?
Yes
GO to F5 .
No
Go To Pinpoint Test U to continue diagnosis of the integrated circuit display. F4 CHECK FOR CORRECT PCM OPERATION
  • Disconnect all the PCM connectors.
  • Check for:
    • corrosion
    • pushed-out pins
  • Connect all the PCM connectors and make sure they seat correctly.
  • Operate the system and verify the concern is still present.
  • Is the concern still present?
Yes
INSTALL a new PCM. REFER to Section 303-14 . TEST the system for normal operation.
No
The system is operating correctly at this time. The concern may have been caused by a loose or corroded connector. F5 CHECK FOR CORRECT INSTRUMENT CLUSTER OPERATION
  • Disconnect all the instrument cluster connectors.
  • Check for:
    • corrosion
    • pushed-out pins
  • Connect all the instrument cluster connectors and make sure they seat correctly.
Yes
INSTALL a new instrument cluster. REFER to Instrument Cluster in this section. TEST the system for normal operation.
No
2003 Hyundai sonata location fuse for speedometer
speedometer runs with several sensors cluster fuse if nothing works in cluster on key on cycle but speedometer uses both vehicle speed sensor and right front wheel speed sensor to operate . Vehicle speed sensor is located on top of transmission near right axle shaft
2answers
The speedometer on my 2004 Pontiac Montana quit working. Is there a fuse for that?
Nope. The speedometer needs a signal from the vehicle speed sensor to operate. Is the check engine light on? If so, scan for any codes that may indicate a VSS problem. If no codes, possible internal cluster issue with the speedometer head
1helpful
What is the location of fuse for speedometer on 2o04 ford explorer
Speedometer The instrument cluster receives the vehicle speed sensor (VSS) signal from the powertrain control module (PCM) through the standard corporate protocol (SCP) communication network. The instrument cluster monitors the VSS input from the PCM and commands the speedometer with a corresponding movement of the pointer.
  • Circuitry.
  • Powertrain control module (PCM).
  • Instrument cluster.
  • Go To Pinpoint Test L .
PINPOINT TEST L: THE SPEEDOMETER/ODOMETER IS INOPERATIVE Test Step Result / Action to Take L1 RETRIEVE THE RECORDED DTCS FROM BOTH CONTINUOUS AND ON-DEMAND INSTRUMENT CLUSTER SELF-TESTS
  • Use the recorded instrument cluster DTCs from the continuous and on-demand self-tests.
  • Are any instrument cluster DTCs recorded?
Yes
If instrument cluster U1123 is retrieved, REFER to Powertrain Control/Emissions Diagnosis (PC/ED) manual to continue diagnosis.
For all other instrument cluster DTCs, REFER to the Instrument Cluster Diagnostic Trouble Code (DTC) Index.
No
For inoperative speedometer, GO to L2 .
For inoperative odometer, GO to L3 . L2 CARRY OUT THE SPEEDOMETER ACTIVE COMMAND USING THE DIAGNOSTIC TOOL
  • Connect the diagnostic tool.
  • Select the instrument cluster speedometer active command.
  • Trigger the speedometer and scroll in increments of 10% while monitoring the speedometer. The speedometer should increase in increments of approximately 20 km/h (12 mph) for each 10% change.
  • Does the speedometer increase within specifications?
Yes
No
GO to L4 . L3 MONITOR THE INTEGRATED CIRCUIT DISPLAYS
  • Do the compass, air temperature or message center displays operate correctly?
Yes
GO to L4 .
No
Go To Pinpoint Test AE . L4 CHECK FOR CORRECT INSTRUMENT CLUSTER OPERATION
  • Disconnect all instrument cluster connectors.
  • Check for:
    • corrosion
    • pushed-out pins
  • Connect all instrument cluster connectors and make sure they seat correctly.
Yes
No
The system is operating correctly at this time. The concern may have been caused by a loose or corroded connector. CLEAR the DTCs. REPEAT the self-test. There isn't a fuse just for the speedometer , there are four fuse for the whole instrument cluster . If one of these fuse's were burnt you would have more then just the speedometer not working ! You need to have a scan tool to find out what is up ! you could need a new cluster ! Is the check engine light on ? if not wouldn't think vehicle speed sensor bad , besides speed info for speedometer PCM uses for transmission shift points ! Good luck ,hope this helps !
Checkout a 2005 buick rendiverous speedometer circuit
Speedometer and/or Odometer Inaccurate or Inoperative
Test Description
The number below refers to the step number on the diagnostic table.
  1. This test procedure may cause DTCs to set, which may cause other systems to be inoperative or disabled.
Step
Action
Yes
No
Schematic Reference: Instrument Cluster Schematics
Did you perform the Diagnostic System Check - Vehicle?
Go to Step 2
Go to Diagnostic System Check - Vehicle in Vehicle DTC Information
  1. Install a scan tool.
  2. Raise the vehicles drive wheels. Refer to Lifting and Jacking the Vehicle in General Information.
  3. Start the engine.
  4. Place the transmission into drive.
  5. With the scan tool, observe the Vehicle Speed Sensor (VSS) parameter in the engine control module (ECM)/powertrain control module (PCM) Engine Data 1 data list.
Does the VSS parameter match the speedometer display?
Go to Step 3
Go to Step 4
Does the odometer operate properly?
Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
Go to Step 4
Replace the instrument panel cluster (IPC). Refer to Control Module References in Computer/Integrating Systems for replacement, setup, and programming.
Did you complete the replacement?
Go to Step 5
5
  1. Operate the system in order to verify the repair.
  2. Use the scan tool in order to clear the DTCs that may have set in other modules during diagnosis.
Did you correct the condition?
System OK
Go to Step 2
1helpful
Speeedometer cable location, cable seems to be loose?
Your vehicle's speedometer doesn't have a cable that drives it, the speedometer is all electronic and uses information from a speed sensor to operate a servo motor in order to move the speedometer needle. If your speedometer is erratic or sticks at one speed then you may have a bad servo motor in the dash unit. The instrument clusters are repairable should this be the problem. Good luck and hope this helps!
How do I reset the speedometer needle that's trapped behind the stop post
u don't rest it, u must remove the speedo and send it out for repair, there is a reason why the needle did this, the electronics have failed that operate the speedometer needle and cuase it to jump over the post, a common problem
Does the same fuse operate speedometer and odometer? If so, where is it located?
if your dash is not digital than u do not have a fuse for the speedometer. it is a cable that goes from the transmission to the back of your gadge cluster.
2answers
'85 CJ7 Speedometer INOP
You should have a speedometer cable that runs from the back of the trani, thru the fire-wall, and into the back oh the gauge cluster.
2answers
My speedometer and cruise control both quit working
try replacing vehicle speed sensors. you need a good vehicle speed signal inorder for cruise and tha speedometer to operate properly
Top Yamaha Experts
vince
Steve Sweetleaf
Steve Sweetleaf
littlewheel
Are you a Yamaha Expert? Answer questions, earn points and help others
