I have a Kenmore washer tube wont spin out the motor runs and will drain the water but wont spin
Hi, Do you know if the washer agitated at all? If the washer does not agitate or spin, the coupler is most likely the cause. If the washer agitates and does not spin, it could be spin basket drive or transmission.
Please let me know so I can assist you further.
Vic
Check the drain hose settings to make sure that there is no chance problem that you have a siphoning problem (eve if it drains). Check the pressure switch as this may prevent the spin part of the cycle from starting.
