Quit in mid-wash cycle (didn't spin) No lights, no response from control panel. Reseated control board - still nothing.
SOURCE: Fisher Paykel GWL11 Top Loader Washer
Please dont put any more money into this machine,if you wait long enough it will take alot more than a penny.
SOURCE: my fisher paykel eco smart is GWL11 not GWL15
00110001 CODE 49 COLD VALVE FAULTY
1 FILTER IN HOSE AT TAP END CLOGGED OR FILTER IN VAVE AT MACHINE END OF HOSE CHECK THESE FIRST .
2 SOLENOID OPEN CIRCUIT OR BECOMING OPEN CIRCUIT WHEN HOT.
3 CONTROLLER NOT SUPPLYING VOLTAGE TO SOLENOID.
TRY THINGS IN THIS ORDER AND GOOD LUCK
SOURCE: Fisher and Paykel GWL11 will not drain...
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
SOURCE: fisher paykel gwl11
Hi Alan.. usually if there is a problem where the diverter valve is not sensed by the machine control, it will throw a fault code and beep and not complete the cycle. There should be a tech sheet under the control panel. Did you make sure you properly re-connected the two orange wires on your new diverter valve?
I certainly have encountered several over the years where the control stops puting voltage to the diverter in recirculate mode.
If you want to be able to use all the cycles on the machine, then you need a new control board. That is part #420094USP and can be purchased from Fisher Paykel Parts direct;
http://fisherpaykelparts.net/index.php?categoryid=111&productid=26
If you need to do laundry in the meantime, use the PERMA PRESS wash cycle, it should work for you, as that cycle does not use the diverter valve.
Also inspect your water pump and make sure it isnot wet or leaky, as this can cause the machine control to either short out altogether or lose functionality on some cycls such as you are experiencing.
I hope this info is helpful to you.
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
