Remote is not working. replaced batteries but its not doing anything. TV is on auto and keeps changing channels
SOURCE: 1999 sansui tvm1915 tv
You'll most likely need a Sansui remote made to work with your specific model TV. I have similar problems with my Toshiba TV. Check eBay.
SOURCE: Sansui without remote
No. You will need the remote. Call the number on the set for an original. You could try your luck with a universal remote. Try a RCA brand. Good Luck!
SOURCE: manual buttons on set will only accept 3 channels
found solution by holding down both volume buttons at same time which enables on-screen menu allowing to select channel auto program
SOURCE: HOW TO REMOVE PANEL LOCK ON A SANSUI LCD TV WITHOUT REMOTE
That tv usually has the customer service number printed on a sticker somewhere on the tv. Give them a call. They will help you for free. I hope this helps you.
SOURCE: how to program a universal remote for the Sansui
It may mean that the code you entered is incorrect. Try these: 0135, 0310 and 0394.
